Ford F250 sagging up front
   / Ford F250 sagging up front #11
I've had pretty good luck with 4wheel parts , this link is for your bushings...
   / Ford F250 sagging up front #12
As long as you have it apart, do a complete front bushing set. Do the springs and hangers, sway bar ect. There are also some bushings where the IFS bolts/pivots on the truck frame. Check those. As long as you're doing the work and have 1/2 apart, it would be worth at least looking at those.
Get some good penetrating fluid. Hit every nut and bolt on that front end every night for a week. Some of those bolts can be a bear.
While the spring shop is at it, an extra leaf would probably help. That diesel is pretty heavy up there.
This does sound like a TBN work party... 4 or 5 people could get this going pretty quick. A couple under the truck, a couple handing wrenches and advice, someone handling the bbq and beverages /forums/images/graemlins/grin.gif Have to meet twice though. One saturday to tear it apart, and the next saturday to put it back together after getting the springs back /forums/images/graemlins/grin.gif
Thanks for all the advice guys. Robert, your right, I checked these links and without a doubt a new complete bushing set is in order. Now, when can I afford to be without my truck?
   / Ford F250 sagging up front #14
That's the tricky part... I had mine done the first time. It was at the shop for two days; one to tear down and send the springs out, one to get them back, reinstall, and align. The second time around, I did the straight axle; that took me a week, but I was also doing other stuff to the truck at the same time.
Getting the springs out and back in is pretty simple. Doing the pivot bushings will take a while.
Plan it for sometime in a couple weeks. I'll come give you a hand.
Ford Super Duty Pickup Truck Bed (A52377)
Ford Super Duty...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2006 International 9400i (A55218)
2006 International...
2015 INTERNATIONAL LONESTAR SFA 6X4 ROAD TRACTOR (A52706)
2015 INTERNATIONAL...
JOHN DEERE 3032E TRACTOR (A54756)
JOHN DEERE 3032E...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
