Ford Model 1920 Tire/Rim help
   / Ford Model 1920 Tire/Rim help
Well, one more source dried up, the used pair was already sold.
This is getting depressing.
I called one more place.
The hunt continues
   / Ford Model 1920 Tire/Rim help #22
when you work on antiques.. that's half the fun.. when it's yer work tractor.. it ain't fun! :(
good luck
soundguy
It is a 'saving my ***' tractor. The guy who does our private road is 62 and health is so-so. This is my attempt at being independent. I am 1.2 km from paved, ploughed road. And if something were to happen to him, I'd be in trouble (vis-a-vis winter snows) I got the tractor for $7100 cdn, and it has 1150 hrs on it. It runs great and I am in the information technology field and I wanted something that was going to get me working with my hands. But it seems Im working the phones (LOL). I would at some point like to learn about the mechanical side of it, ergo the cheaper, used tractor. I've ordered the operators manual and for ***** and giggles the "Service Manual" for light reading in the winter.
508 pages....
I have a buddy who is mechanically inclined and he can show me some stuff, but I want to ease into this easily. There is no way in **** I'm taking this thing apart unless I have to. But I like the idea of reading up on it, for what good it may do, who knows...
   / Ford Model 1920 Tire/Rim help #24
Are you sure the wheels are set as narrow as they can be? Over 6' sounds wide even for those tires. Were the wheels set wide for mowing hillsides by chance?
   / Ford Model 1920 Tire/Rim help #25
Would custom made hot dip galvanized used rims in a 24" size, with flat centers that can easily be drilled to your bolt pattern interest you? I have some extra ones that I have ripped the tires on, and just grabbed another instead of having the tire dismounted/remounted. Dismounting the old tire, shipping to you would have to be considered, since I am in Jacksonville, Florida
Not very good pictures, but I had them. The center plate is half inch thick steel. I drilled the hole size out to fit my JD2555. The pattern was right, just bolt hole too small.
David from jax
(not the turf rims, just the ag rims)
   / Ford Model 1920 Tire/Rim help #26
those turfs set wider than ag tires..
soundguy
   / Ford Model 1920 Tire/Rim help #27
I can hear the next two questions...
What is the offset of my rims and what will they cost me delivered?
Guess I better go get the tape measure out...
David from jax
From web they have 3.75 to outer edge on one side and 8.5 on the other. Web is 1/2 thick. Rim is 26" diameter with 14.9-24 inch tires mounted on them. (I wish they were 26 inch rims as they are a little short for my tractor)
David from jax
I think the shipping from FL would kill me, and if the solution didn't work.. I'd have two nice flower pots :D
I will wait until this last guy calls me back and see what he has to offer. I measured it again and her arse is almost 7 feet, and yes those turfs do set out quite a bit. Every time I see TractorData.com, a 1920 with those AG's make my whiskers twitch.
If I ever pull this off, the next project is the blower, a five footer.
This is almost as much work as when I installed my 1.5kw photovoltaic system two years ago..
   / Ford Model 1920 Tire/Rim help #29
I wouldn't ship them either, until I KNEW that they would solve the problem. It is only a 3600 mile round trip, so you should be able to run down this weekend and pick them up and be ready to go back to work on Monday!(LOL!!)
Let me know if you change your mind.
David from jax
Given the winter we just had, I would probably do the drive.
Now, I think I mentioned this in a post, but if I went with 26" or 28" rims, I assume I could still get a 13.6 ag tire, and what size would the front rims have to be? (if someone wishes to do the calc)
I like the tractor, and one of my buddies said, sell it, chalk it up to a mistake and buy a new one, but I think a new tractor with the same power as the 1920 up here would run me 20k+ (including our beloved taxes).
SoundGuy mentioned I must maintain the circumference ratio, as well I may end up with a slightly faster tractor at any given gear. I'm ok with that, since I think I will have better luck with a 26 or 28" rim. I mean, they build monster trucks right? :eek:
I should be hearing from one other source today (CASE), he mentioned also that Kubota uses a 24" rim.
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
48in Forks and Frame Skid Steer Attachment (A56857)
48in Forks and...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2016 FREIGHTLINER  CASCADIA TADC (A59575)
2016 FREIGHTLINER...
