Ford NH 2120 oil dripping from valve cover tube
   / Ford NH 2120 oil dripping from valve cover tube #1
smclaughlin81
Valleyford, WA
Ford New Holland 2120 (compact diesel, Ford 1210, NewHolland LS45
Afternoon everyone, I have a 1996 Ford NH 2120, under 900 hours, starts right up, runs good, has plenty of power. The other day I was grading my driveway and had stopped to pickup some rocks. When I got back on, I happened to look down on the right side on the ground and saw a small puddle of oil, black. I got off and came around the side and found it to be dripping from the valve cover breather tube. I raised the hood and removed the oil fill cap and oil was spitting out, not a ton, but enough to close it back up.
First thought, increased crankcase pressure, head gasket? I suppose if it failed between cylinders. Oil level was normal, actually probably a half quarter low, which it had been for awhile, so I felt good that it wasn't over full. So I dismissed hydraulic oil leaking in from the pump, diesel leaking inside the motor. Guess I'm looking for suggestions. I did order a compression test kit from Amazon, should be here today. Should I be looking at something else? Like I said, no noticeable change in performance.
   / Ford NH 2120 oil dripping from valve cover tube #2
Over 20 years ago my Ford 1310 had a head gasket failure in the middle cylinder, but there was no external leak or no mixing of oil/coolant, just excessive venting from the breather hose.
The head gasket had a small failure and it was only in the area where there is a push rod opening, thus allowing some of the middle cylinder compression to escape to the valve cover area and be vented out to atmosphere with some oily mist!
I changed the gasket and it's been good ever since.
Over 20 years ago my Ford 1310 had a head gasket failure in the middle cylinder, but there was external leak or no mixing of oil/coolant, just excessive venting from the breather hose.
That's reassuring, I'm going to check compression and see if that shows something. Thanks for the input!
20711 (A50323)
20711 (A50323)
CFG Industrial SAII100 (A50123)
CFG Industrial...
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
Kubota BX2230D (A47384)
Kubota BX2230D...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
2025 CFG Industrial MX15RX (A50123)
2025 CFG...
