aczlan
Good Morning
- Joined
- Mar 7, 2008
- Messages
- 16,985
- Tractor
- Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
Tires, wheels, ABS clamping a little closer to traction limits, or someone not hitting the brakes equally hard?Anyone know why the Ford with all it's aluminum, had a worse brake distance than the Dodge which is 1,000 heavier?
Here are the specs on Ford brakes:
And on the Chevy brakes:https://media.ford.com/content/dam/fordmedia/North%20America/US/2015_Specs/2015_F150_Specs.pdf said:BRAKES: Four-wheel vented discs
Front 13.8 x 1.34 in., dual 2.1in. pistons, non-asbestos organic linings
Rear 13.2 x 0.87 in. (electric parking brake) 13.7 x 0.98 in. (drum in hand), single 2.13-in. pistons,non-asbestos organic linings
http://media.chevrolet.com/media/us/en/chevrolet/vehicles/silverado/2015.html said:Four-wheel disc brakes. The large, vented front brake rotors measure 13 inches in diameter and are complemented by 13.6-inch rear rotors. An enhanced brake vacuum pump introduced in 2014 improves braking capability through greater brake system boost, while the brake pedal assembly itself is lighter, for a more uniform, linear feel throughout the entire pedal travel range.
It must be a secret as to the size of the 2015 Ram 1500 brakes because I couldn't find it listed anywhere.
I finally found it for the 2013s:
http://www.allpar.com/model/ram/2013-ram.html said:Four-wheel disc brakes are standard on all 2013 Ram 1500 trucks. Front rotors measure 13.2 inches (336 mm) in diameter and are clamped with dual-piston calipers, while rear rotors are 13.8 inches (352 mm) and utilize single-piston calipers.
Aaron Z
