Ford Selecto-speed
/ Ford Selecto-speed #1
Russ5160
Have a Ford 3400 Selecto-speed and the transmission is giving me problems. Can I put a standard 8 speed transmission from a Ford 2000 together in the place of the old selecto-speed ?
Russ
/ Ford Selecto-speed #2
If I remember right, you will need everything from the bell housing back. I think even the reared has a different ratio.
/ Ford Selecto-speed #3
I owned a early 4 Cyl. 4000 with the SOS for about 4 years and I liked the SOS. From what I've read, the SOS has lower 1st gear than the manual transmission. This is a good thing for Tilling as you need to just crawl speed for that. I wouldn't give up on the SOS yet. There are still some good service people around that can trouble shoot those transmissions and would be lest costly than a major swap of all the components that would be required. See who you can find to help you with the tractor transmission. bjr
The only guy I know around here is retired, and he told me it would cost too much to make it worth it.
So that's why I'm hoping to find the back half.
/ Ford Selecto-speed #5
This is a good thing for Tilling as you need to just crawl speed for that.Select-O-Speed Parts at Dennis Carpenter Ford Restoration Parts.
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
1985 Ford Ltl9000 Tender Truck (A63688)
1985 Ford Ltl9000...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2018 International HX620 Quint Dump (A62613)
2018 International...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
2025 IRET13 Electric Tricycle (A61574)
2025 IRET13...
