Ford Selecto-speed
/ Ford Selecto-speed #1
Russ5160
Have a Ford 3400 Selecto-speed and the transmission is giving me problems. Can I put a standard 8 speed transmission from a Ford 2000 together in the place of the old selecto-speed ?
Thanks
Russ
/ Ford Selecto-speed #2
If I remember right, you will need everything from the bell housing back. I think even the reared has a different ratio.
/ Ford Selecto-speed #3
I owned a early 4 Cyl. 4000 with the SOS for about 4 years and I liked the SOS. From what I've read, the SOS has lower 1st gear than the manual transmission. This is a good thing for Tilling as you need to just crawl speed for that. I wouldn't give up on the SOS yet. There are still some good service people around that can trouble shoot those transmissions and would be lest costly than a major swap of all the components that would be required. See who you can find to help you with the tractor transmission. bjr
The only guy I know around here is retired, and he told me it would cost too much to make it worth it.
So that's why I'm hoping to find the back half.
/ Ford Selecto-speed #5
This is a good thing for Tilling as you need to just crawl speed for that.Select-O-Speed Parts at Dennis Carpenter Ford Restoration Parts.
Willmar 4550 Wrangler Articulating Loader (A63689)
Willmar 4550...
HYSTER H80XM STRAIGHT MAST FORKLIFT (A64279)
HYSTER H80XM...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
1991 25ft Wellcraft 250 Sportsman Boat with 1980 27ft Float-On T/A Boat Trailer. (A61574)
1991 25ft...
UNUSED WOLVERINE HYD MINI AUGER (A64281)
UNUSED WOLVERINE...
