Ford Selecto-speed
/ Ford Selecto-speed #1
Russ5160
Have a Ford 3400 Selecto-speed and the transmission is giving me problems. Can I put a standard 8 speed transmission from a Ford 2000 together in the place of the old selecto-speed ?
Thanks
Russ
/ Ford Selecto-speed #2
If I remember right, you will need everything from the bell housing back. I think even the reared has a different ratio.
/ Ford Selecto-speed #3
I owned a early 4 Cyl. 4000 with the SOS for about 4 years and I liked the SOS. From what I've read, the SOS has lower 1st gear than the manual transmission. This is a good thing for Tilling as you need to just crawl speed for that. I wouldn't give up on the SOS yet. There are still some good service people around that can trouble shoot those transmissions and would be lest costly than a major swap of all the components that would be required. See who you can find to help you with the tractor transmission. bjr
The only guy I know around here is retired, and he told me it would cost too much to make it worth it.
So that's why I'm hoping to find the back half.
/ Ford Selecto-speed #5
This is a good thing for Tilling as you need to just crawl speed for that.Select-O-Speed Parts at Dennis Carpenter Ford Restoration Parts.
2007 Ford F-150 Crew Cab Pickup Truck (A61573)
2007 Ford F-150...
COMBINATION ELECTRICAL & COOLING SYSTEM (A64281)
COMBINATION...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A61573)
2019 Chevrolet...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A63688)
2023 Kubota...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
