Ford to introduce another pickup, smaller than the new Ranger.
   / Ford to introduce another pickup, smaller than the new Ranger. #41
That engine was the Ford Europe 2.3 originally seen in the US in the pinto. The later dualspark head was used in the Ranger and Mustang.
The 5-speed manual, on the other hand, was from Mazda and used in the Ranger and F-150.
I loved the 2.3/5-speed in my 96. The 2.8 in my 85 was fun, but fussy (had the intermittent distributor ignition module problem, and the carb iced over on humid days until I bolted the intake heat riser flap in the air cleaner housing shut to always add heat). When the exhaust donut burned out (about once a year until I gave up and swapped out the flex fitting for just a straight repair piece) it was downright peppy, good enough to make driving on 128 fun.
   / Ford to introduce another pickup, smaller than the new Ranger. #42
When is driving on 128 fun 2 am....:)
   / Ford to introduce another pickup, smaller than the new Ranger. #43
The 2.3 16 valve four ? And the 2.8 Cologne pushrod V6 with three exhaust ports ?
The Cologne V6 was built in 2.0, 2.3, 2.4, 2.6, 2.8, 2.9, 3.0 and 4.0 liter, the 4.0 being a North America exclusive, and the smaller V6 all had two exhaust ports per bank, so they fitted in the Taunus engine bay where normally the V4 was fitted. I think only the 2.4, 2.6, 2.9 and 4.0 had three exhaust ports.
Ford Cologne V6 engine - Wikipedia
The 2.3 16 valve put out 150hp, about the same as any standard Ford pushrod version of the Cologne V6 did...
New/Unused Electric Golf Cart (A57453)
New/Unused...
Toyota LPG 7FGCU20 3,400 Lb. Forklift, S/N 86163, Dual Mast, Tilt, 19,871 Hours Indicated, Asset#... (A59076)
Toyota LPG 7FGCU20...
1993 FORD F-350XL SINGLE CAB FLATBED TRUCK (A51406)
1993 FORD F-350XL...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A58018)
2013 KENWORTH T680...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
