slowzuki
Elite Member
- Joined
- Sep 19, 2003
- Messages
- 4,156
- Location
- New Brunswick, Canada
- Tractor
- Kubota L5030 HSTC, MF 5455, Kubota M120, Allis Chalmers 7010
Egon I like how you made a statement in the form of a question! Why yes, yes compression matters in a way.
The efficiency is a function of the mean effective pressure delivered to the piston face for a given amount of fuel.
You can raise this by compression ratio, turbo/supercharging, injection strategies, timing advance etc etc but the main problems are:
-high pressure requires high temperature as per ideal gas law.
-high temps melt pistons, erode ceramic coatings, change nice tight clearances in the engine parts
-high temps make lots of NOx pollution.
So regardless of what some people in this thread think, you can't just magically increase the efficiency because that means hotter combustion at higher temps.
I've discounted the throttling/pumping loses because they are minimal in modern engines and certainly not a key factor. Only a problem for people looking for high hp.
