Forks for a CT 235
   / Forks for a CT 235 #1
lilranch2001
Super Member
Bobcat CT 235
I was under the impression that I could get forks for my new tractor, but Bobcat does not list them for this tractor, does anyone know more than this?:tractor:
   / Forks for a CT 235 #2
Search the forum for forks there are many many alternatives
eBay also has many listed
I made my own for about $40
Joel
   / Forks for a CT 235 #3
I'm getting a used set from my Bobcat dealer in a couple of weeks for my CT230. They are a rental set that they are gonna trade-off.
I do have the Bob-tach though. Do you have Bob-tach?
yup, I do, do you know the part number?
   / Forks for a CT 235 #5
You can get clamp on the bucket edge forks,but only useful for light duty.It will lower lift capacity because they are too far ahead.I,v used a set I made for my 235 but only lift about 4-500 pounds.You,ll have to have loaded tires for sure and I only use it at the garage.Wouln,t ever consider going more than about 30 feet with anything on my forks.If you have b-tach you sould be able to find a used set,they don,t get used much by the average guy.Handy when you need em though.
   / Forks for a CT 235 #6
No part number but would just be a skidsteer attachment. Try looking that way.
thanks, I will
   / Forks for a CT 235 #8
since you are bobtach you can get the forks from anywhere i believe and may be cheaper. they are all skid steer quick attach. many have had luck with everythingattachments.com.
Thanks, I found that site earlier today, I am going to give them some serious consideration since they have free shipping, and seems like they have a good line up of products :D
   / Forks for a CT 235 #10
I have a set that chain on the bucket with a chain ratchet or load binder. They work well and will handle anything that the tractor can. I use them at least once a month. The only downside is visibility. Hard to see what you are doing sometimes. The upside is they were only about $125.
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
14ft x 20ft Single Garage All Metal Building (New/Unused) (A59225)
14ft x 20ft Single...
2009 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2009 Ford F-150...
(4) 275/70/18 TIRES (A58374)
(4) 275/70/18...
2007 34ft. Homemade Pipe Trailer (A55973)
2007 34ft...
2021 Caterpillar XQ125 125kVA Towable Diesel Generator (A55973)
2021 Caterpillar...
