Hey there fellow TBN Chinese tractor owners,
It's been a long time since I posted.. I have been wearing this thing out learning how to use it and what best to use it for and hey may have even come up with some crazy ways to use it.. BTW they excel at putting out field fires
Since my last post I finally acquired some land to use my tractor on which is a good thing it sure was tearing up the backyard playing with it.
I have put near 100 hours on it since buying the land and had a few questions.. Some of which I may have not paid attention to prior to being more familiar with the machine but wanted to ask the crowd what they thought.
First PTO.
All is still working as it should but I think this symptom is new. When I first bought it with 600 hours on it I swore the PTO was quiet and rarely if ever moved when it was not in gear. If it did move it was pretty easy to stop with your shoe.. I think! Now although it is still working fabulously for my bushhog I think something may be different. First I have punished this little bush hog and subsequently the PTO while cleaning up this property. It has found tire after tire buried in 8ft weeds, grass, and trees. An uncountable number of large rocks, and bricks. and the occasional what the heck was that shooting out of there item. But it is why I bought a cheap used one because I had no idea what was out there or under all that tall stuff. Apparently this guy used the property as a dump site..
I digress BACK TO THE PTO.. the PTO now seems to "whir" even when not in gear. When I reach down to stop it, it seems to stop easy enough but it keeps on whirring moving or not and feels much like a ratchet being turned the wrong way.. with only slight resistance. Is there a one way in there? I thought this was straight gears and no funny stuff in between.
Next Clutch.
Have the manual but wanted an education. Again this is where I am not sure that I ever noticed and only now notice due to more time on the tractor or has gotten this way with use.
No problem shifting gears except occasionally (usually that's when I have forgotten the throttle lock engaged). But, it seems to release at the top of the pedal, and it has absolutely no linkage slack. That is where I need the education I believe I am reading my manual right and it should have a little slack in it.. Or is that to engagement looking through the inspection hole? Currently have proven I cant slip it, it will churn all 4 tires if I butt up against a big tree and hasn't failed to climb the hills on the property and noengage it into neutral. high revs at anytime.
As always guys thanks for any help
Rick
