Foton: Instal an inline filter on hydrolics
   / Foton: Instal an inline filter on hydrolics #11
Thank you Ron for the answer but the answer brings more questions.. Where does the fluid return when the 3PTH is not moving and the steering is also still? If the Divider is a 50/50 divider it would seem that some fluid would flow all the time. I added a tap in the line when I added the filter. A lot more fluid flows out the tap when the engine is running than when the engine is not running. I think the power steering works when I am lifting with the 3PTH so I suspect it is a simple Divider. I am a novice a best on hydraulics with a strong desire to learn.
Harold
The block after the FEL valve is a priority type diverter not a divider. Most all the fluid flows down the line to the 3PH control valve. With the 3PH control valve in the hold or lower position, all this flow passes thru the valve body and into the resovoir thru the wall of the resovoir. When you lift the 3PH control lever, this flow is diverted from the resovoir to the 3PH cylinder. A very small ammount of fluid is allowed to pass from the diverter to the steering system. A little may leak by the vane pump and back to the resovoir, but not very much. As soon as you start to turn the wheel, that vane pump/valve at the end of the steering column allows a lot of fluid to flow to/from the steering cylinder. As soon as this fluid is allowed to really flow, the change in pressure this creates in the diverter forces the diverter piston to shift the flow/pressure to the steering system in preference to the 3PH. this pressure does the work, with the vane pump via the steering wheel directing the flow. As soon as you stop turning the wheel, you halt the flow, and the diverter shifts the flow back to the 3PH. That vane pump is just that, a pump. This allows you to still work the steering when the engine is not running. Without hydraulic pressure from the engine pump, the steering vane pump becomes basically a closed system and uses just the fluid in the steering cylinder and lines.
The diverter allows steering to take priority over the 3PH. If you try and lift the 3PH while turning the wheel, the 3PH will slow or not move untill you stop turning the wheel.
   / Foton: Instal an inline filter on hydrolics #12
I am pretty sure fluid only flows thru that return line from the steering when you are rotating the steering wheel, and then only the volume that is being moved out of the steering cylinder...
Ok guys. On a Jinma 254, not sure about a Foton, it has a open center system. That means if the fluid coming from the pump is not being called on for a use like FEL, 3 point, or steering it just makes a loop to the reservoir. It is always flowing. I put a 10 micron filter that was made for a log splitter on the return side.
Chris
Greetings Mates and Welcome, Yes! it's cold here 12 above today. The tractor has ATF now, I'll replace it with 32 iso hydro. Is ISO the same as AW?
I saw the suction you put on yours, nice job, I think I would like to put a filter on the return, thinking both that it will be easer to seal and worry of starving the pump. I'm not sure which is the low or no pressure return yet. The fellow that had the tractor put the FEL on later getting the FEL form the same company. Maybe it is a smaller pump, when I get a moment I'll try to find out what size pump it is. I'm not sure what an open system is.
When I get back later I'll read more of what you guys have written and answer more completely. I have a bit of work to do away from the house. Richard
   / Foton: Instal an inline filter on hydrolics #14
Identical. ISO is an "international" designator, AW is American. What's important is the number that follows.
//greg//
   / Foton: Instal an inline filter on hydrolics #15
If you are refering to my picture it is on the return side. As for the OPEN CENTER System it is a system that is always producing pressure by the pump. If not needed it simply makes its way back to the reservoir. Once called upon to do a job like move the 3 point it directs the fluid to the 3 point valve to do the lifting of the arms. Same holds true for steering and FEL operation.
Chris
   / Foton: Instal an inline filter on hydrolics #16
Nope, two completely different animals.
The International Organization for Standardization (ISO) is a technical body that works in conjunction with ASTM, SAE, DIN, DNV, and others, to establish world wide minimum standards (this is taking some time, and meanwhile UN climate body suspends DNV's accreditation - Forbes.com DNV got their hands slapped).
Anti-Wear (AW) is the designation given to oil companies for proprietary additive packages that meet certain minimum standards established by SAE through ASTM.
   / Foton: Instal an inline filter on hydrolics #17
Chris
Chris
I think you are only filtering the fluid that passes thru the steering system. I believe the main flow has always been back to the 3PH valve on the right side of the tractor. I don't think the 200 series Jinma originally had power steering. It was an afterthought/improvement. They added it by putting in the diverter valve located down by your right toe. As I understand it, this selectively re-routes the flow to the steering only when needed. There might be a little leakage thru the steering vane pump, but I would imagine the only real flow you get thru that filter is when the steering wheel is turning.
Richard
I am not specifically familliar with your Foton, but if it is like most of these basic designs, putting in a return line filter is a problem. In order to do it, you need to put it on a low pressure return line with an unobstructed path to the reservoir, AFTER the last valve in the system. Everything upstream of that last valve all the way to the pump will be exposed to maximum system pressure of around 2200 PSI when you lift something heavy with the 3PH. The last valve in these systems is typically the 3PH valve. It's low pressure outlet to the reservoir is thru the side of the valve that is bolted to the reservoir wall. It is basically inaccessable without re-designing how the 3PH control valve is mounted and plummed...
Well I'm back. I have ISO 32 should I get AW 32? I think the tractor does have an auxillary hydraulic output it is located to the right side of seat it is from there the first owner has a hose going to the FEL. Are you saying there is a vane pump in the steering unit? I haven't got down to look yet, is it driven by the hydro pump.
When the tractor is running and nothing is in operation the fluid is being pumped. there should have a return back to the tank. This would be a low/no pressure line?
I like the idea that the pump is too small that would seem an easy fix. Richard
   / Foton: Instal an inline filter on hydrolics #19
RonMar, I am guessing your tractor is plumed different than mine.
The way my tractor is plumed goes like this:
Reservoir
Pump
FEL
Diverter Valve
From the diverter valve there is one input, coming from the FEL, then 3 out puts. 1 just goes straight back to the reservoir like a bypass for the open center system, another goes to the steering then back to the reservoir, and the last goes to the 3 point then on to the reservoir.
The hose going from the diverter to the reservoir and the hose going from the steering to the reservoir share a common pipe running down the left side of the tranny. This is where I cut into the system and put a 10 micron return filter. So in essence it is filtering any fluid that has went through the FEL, diverter, steering, and the bypass for the open center return. It is not filtering the fluid that has been called upon to operate the 3 point which just dumps back into the reservoir.
Chris
Chris, I just reread your last post. There are two or three hydro lines going to the hydraulic tank, I'll get under and around and see if there is a similar set up that sounds good. Should I get AW 32? I have ISO32. Richard
2018 Atlas Copco Pas200HF Diesel Dewatering Pump (A52377)
2018 Atlas Copco...
Sterling AT (A55301)
2019 BOBCAT S770 SKID STEER (A52705)
2019 BOBCAT S770...
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
