Freedom hitch and RFM
   / Freedom hitch and RFM #1
Nik
Bucks County, PA
B3030 Kubota HST
Does anyone have any experience using a freedom hitch with a rear finish mower or brushhog. In particular does it allow the top link portion of the mower to flex as designed? I think they have a top flexible link attachment to allow some motion just like the landpride Quickhitch has for use with finish mowers. I have used the freedom hitch on someone's L3710 for a boxblade and it worked well. I was thinking of getting this hitch for my Kubota B2410. I use a 60" Landpride RFM, 48" WOODS brushbull rotary cutter, and also sometimes use a boxblade and rearblade. I know the are about $200.00 per attachment but I would spend this for the convenience of rapid hookup. I like this setup better than PAT's quickhitch. Precise lineup of the three point hitch and implement is not critical with the FH Also the lower links on the B2410 do not stay spread apart when backing up to attach an implement and this can be frustrating.
   / Freedom hitch and RFM #2
I have used the FH with the accessory connector that provides for implement float and it works well.
JackIL
Jack
Thanks for you input. I will probably get the Freedom hitch later this spring and report back then.
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A56435)
LIKE NEW 2023...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
