French Drain Project.
/ French Drain Project. #1
JSUnlimited
Platinum Member
Ohio
New Holland
Here's pics of my latest project. In order to cut off some of the water coming off the hill towards my house, I dug a trench 12" wide by aprox 150' or so. It ranges in depth from 20" to 40" obviuosly sloping toward the rear of the house. I used 1 4" perf. pipe wrapped in a sock that ran the length of the ditch in a bed of #57 river gravel about 3-4" deep. I covered the pipe with the #57 gravel to within 1-2 inches of the original grade. Here's some pictures hope it's not boring. The NH TC24DA and 756C hoe saved a lot of work!
Facing toward the front of house.
A little "jog" to catch the spouting line. This was run through solid line separately in the same trench.
This is facing towards the rear of the house were the grade goe down hill.
Another shot of the grade change in the rear.
Sorry there were no pics between the open trench and the finished project but mother nature was on the way. Here is just after being done. We ended up with 2 inches of rain in about 45 minutes. This usually would have been a river and had standing water, however this project ended all of that.
Another shot. This worked pretty good, in fact like a dumb a** I went out in the middle of a nasty T-storm to check the end of the pipe and it was flowing very well. The pipes sticking up every 20' will be for surface drains/grates after the grass returns and I get the top soil moved in and the swales made.
/ French Drain Project. #8
Great project, MegaMe, and thanks for including the pictures. I assume the sock is to filter fine sediment?
I hired a contractor to do install a couple culverts and a "grassed waterway" last year. The day after he installed it, we got about four inches of rain in 24 hours! I was like a mother hen, out there checking things out in all kinds of weather. I was routing water into the woods. I was very concerned about slope (even put a slight adverse grade in) because I didn't want to initiate any mass failures of the hillslope with the additional surface water. So far things have held up great, but I know that feeling of wondering how it's working.
I may still end up doing some trenching and french drain installation so I really appreciate your post. Stay dry!
/ French Drain Project. #9
Great looking job, Mega. Reminds me of my own project I did on my house in the burbs about 15 years ago. This house sat on a downhill slope several feet below street grade, and the old drainage system (sched. 40) had failed. I rented a trencher (before my tractor days), and put in the black flexible drainlines with about 10 catch basins. My neighbor, an engineer, came over when I was about 80% done and warned me that this system would never work. Forgot why. It worked well for the 9 years I owned that home.
Steve
Yes the sock according to the manufacturer is supposed to filter out the sediment.
Check out ADS-Pipe, I spent a lot of time there researching!
I bought the pipe at TSC.
/ French Drain Project. #11
Nice project! I did the same thing last year at our house although the bank wasn't as steep. In my case I had originally pitched the grade so it came up from a swale at the bottom of the hill back to the house. Water in the basement wasn't an issue, but I couldn't get anything to grow/hold in that swale. In the spring it became a brook and eroded it into a trench.
Last year I rented a mini-excavator, trenched along my swale, tied the two downspouts at that end of the house and my water softner line in as well. I brought it a good 150'+ and dug a big drywell. I used landscape fabric in the trench (I thought it would help the stone stay free of silt) and I used 3/4 stone up to 3" - 4" to the original grade. Seeded it all and (knock on wood) it's been working great ever since!
/ French Drain Project. #12
Looks great, you're taking no chances with the scuppers! I just finished laying almost 200' of the same drain line and found getting a 100' fabric sock on a 100' pipe is a real PITA. It's like 'Chinese Fingers', the harder you pull the harder it stays put! Thankfully, the sock label included a very handy tip. It bears repeating for those who don't know... cut a 2-1/2' section of 6" pvc to feed the sock onto, then feed the 4" drain tile thru the sock loaded 6" tube, slipping the sock off as you slide the 6" tube down the drain line. Tada.
/ French Drain Project. #13
Our local home improvement stores, Home Depot, sell the perf pipe pre-socked. I need to do some underdrains/curtain drains/french drains/farm tiles whatever you want to call them. I am an engineer and have seen several ways to do it. It seems that rock and perf pipe without a filter is the traditional way to do it. We have had success in the city with a socked pipe and sand to the surface. It seems the sand is less likely to clog with sediment than the rock.
What is the general consensus about pipe, fabric, and backfill in clay type soils. The pipe will be 4 or 6 inch perf pipe.
/ French Drain Project. #14
In your second post I saw a red paint line in the dirt and guessed from another post it was for the gas line. I didn't see any sign of a gas line in the pic by the downspout. Gas lines in Michigan are only about 18 inches deep that close to the house. How deep was yours?
/ French Drain Project. #15
Here in WA, yellow is for gas and red would be phone or power. Good idea to get locates.
/ French Drain Project. #16
Highbeam - what I read is that soils with a higher clay content have a lower ability to move water both horizontally and laterally; therefore, they require tile to be placed shallower and closer together for rapid drainage. Sandier soils can be drained with deeper widely-spaced tile, but tend to need sock or sleeve filters to prevent smaller soil particles that lack cohesiveness from entering the tile.
In clay soil, the U.S. Golf Association recommends 4" corrugated, perforated drain pipe installed at a depth of 2 to 3' with lines spaced from 10' apart when 2' deep to 20' apart when 3' deep and. Backfill the trench with 6 to 12" minimum of #57 washed gravel (1/2-3/4" in size average). For maximum effectiveness, the trench should be backfilled leaving no more than 1' to the ground surface. Use topsoil (not clay) to fill up to the surface layer and use a pipe sleeve regardless of soil type or if in rock or not.
You are lucky, my HD does not offer pipe with preinstalled sleeve. /forums/images/graemlins/tongue.gif
/ French Drain Project. #17
Does width of trench really matter? I ask because rather than dig a big trench with a hoe I can use a chainsaw type trencher and run the pipe quickly and cheaply. Less gravel too. Would want a wide enough trench to work in though.
My boss engineer actually recommends sand as backfill since the surrounding soil is less likely to migrate into the gravel voids and plug it. The sand could be run clear to the surface to pickup surface water more effectively.
Socked pipe seems to be ideal but I'm sure the cost is higher than socking your own.
/ French Drain Project. #19
I don't think that applies to what I meant. Does the width of the trench matter in terms of the pipes ability to dewater the site? Constructability and proper bedding of the pipe being a seperate issue. The reference gave me a 22 inch trench for 6 inch pipe.
/ French Drain Project. #20
The trench width should be no wider than what is represented in the attached table, except as necessary to construct the trench or install the pipe. According to ASTM D 2321, the trench width should be no wider than what is required to safely and conveniently compact backfill material on either side of the pipe. As I understand it, in clay soils you do not want to make wider trenches, rather, you will need additional drain line laterals. More info HERE.
Box of Transport Ratchet Straps (A59230)
Box of Transport...
FORD 5610 TRACTOR (A64276)
FORD 5610 TRACTOR...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63688)
2004 Cadillac...
2014 Crossroads RV Elevation T/A 5th Wheel Toy Hauler Travel Trailer (A61574)
2014 Crossroads RV...
UNUSED WOLVERINE 3PT QUICK HITCH (A64281)
UNUSED WOLVERINE...
Atlas Copco Air Compressor & Air Dryer (A62613)
Atlas Copco Air...
