Front Axle/Front End Problem Ford 1910
   / Front Axle/Front End Problem Ford 1910 #1
artie
Pulling a stump in reverse something started skipping in the front end. Well 4 wd you could not use, the left front wheel locks up. So I used 2wd, now the 2wd is locking up.
should I drop the whole differential off and work on the whole thing? Is that whats probably wrong?
   / Front Axle/Front End Problem Ford 1910 #2
If it were me I would start by removing the drain plugs on the axle and where I found metal I'd investigate further, might help you pinpoint whether it on one of the ends or in the center.
   / Front Axle/Front End Problem Ford 1910 #3
I suspect you are now missing some teeth on your ring gear.
Light Tower (A52377)
3 BATTERY CHARGERS (A53843)
3 BATTERY CHARGERS...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
78'' root grapple (A53421)
78'' root grapple...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
1980 TIGER TA KILL TRAILER (A53843)
1980 TIGER TA KILL...
