Front axle oil low, no leaks
   / Front axle oil low, no leaks #1
BeezFun
Veteran Member
IL
Kubota B2710
B2710, front axle oil level is low, but no signs of leaks and I keep it inside so I'd see oil on floor. I probably added about a pint, maybe a quart of oil to top it up, not sure because I use a bulk loader. Where can the oil be going? I know it was full at the beginning of the season, which was last time I checked it.
   / Front axle oil low, no leaks #2
They come low from the dealer. Should be checked after a few hours use and topped off.
   / Front axle oil low, no leaks #3
Apparently this has been reported many times. It seems to take some time for all of the trapped air in the axle to work out, and when it does the level drops.
Keep in mind when you check the fluid level, the axle needs to be on a level surface
   / Front axle oil low, no leaks #4
I have heard same as above bought my tractor new and now have 135 hours still haven't lost any front axle oil.
Having taken these front wheels apart, it's a bit difficult to imagine how air could be trapped for more than a few rotations of the wheel, especially with lower viscosity fluids like sudt. On the other hand, I can't think of a better explanation.
   / Front axle oil low, no leaks #7
It's true, I drained and refilled mine, checked it a year later and it was at least a liter low.
   / Front axle oil low, no leaks #8
After you top it off this time, you'll probably never need to add any for a long time.
Yeah, I changed mine about a year ago too. Weird
   / Front axle oil low, no leaks #10
It is a conspiracy. Some one is going around and draining out a bit of fluid from everyone's front axle. It don't take long and he could get enough collected to make a living selling it. :laughing: Well hey, it could work!:D
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2013 VOLVO VNL860 TANDEM AXLE SLEEPER (A51219)
2013 VOLVO VNL860...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
2016 Freightliner Cascadia Tandem Axle Road Tractor (A47384)
2016 Freightliner...
2003 CATERPILLAR 420D BACKHOE (A51242)
2003 CATERPILLAR...
