front driveshaft protection?
   / front driveshaft protection? #11
Jim,
Thanks for the reply. I don't have access to a digital camera, so I can't send a picture.
Len Shaeffer, however, did send a diagram of the exploded view of the driveshaft.(Thanks, leonard!)
I'm attaching that here, but I don't see the rubber boot. any ideas?
thanks!!!
   / front driveshaft protection? #12
thanks, Tbrad! How does the boot attach, clamps, bolts?
   / front driveshaft protection? #13
In the diagram, #28 is the support housing....I "think" I already have this--maybe? Is #27 the rubber boot?
I don't see any holes in the differential to mount the bolts indicated on part #28. am I confused or what? /w3tcompact/icons/eyes.gif
   / front driveshaft protection? #14
The support housing bolts on to the end of the differential housing. 27 is the boot
   / front driveshaft protection? #15
Thanks, Len! I think it has finally sunk in....sorry to have beaten this dead horse again!
I'll be in touch off-post.
   / front driveshaft protection? #16
Tony,
Here is the 1401d front coupling, left and right side, by the oil pan. The diagram Len sent you is accurate. In these pics you can see part #'s 31 (bolts), 28 (housing), 29 & 30 (clamps), 27 (boot).
Jim
   / front driveshaft protection? #18
Thanks for the pictures, Jim! Like they say, "a picture is worth a thousand words." I just need to go take a look at my tractor to see if I need the whole set-up...I'm thinking the tractor had this cover at one time because the picture of the support housing looks familiar.
thanks again!!
   / front driveshaft protection? #19
My 1720D is missing the driveshaft cover too. I didn't notice it until I read this discussion. Since I'm somewhat of a perfectionist, I won't rest well until my little red tractor is whole (I also don't want to ruin my seals). I got some great feedback, and ultimately parts, when I told the sad tale of my missing drawbar. If anyone has a lead on a driveshaft cover for a 1720D I would appreciate hearing from you.
   / front driveshaft protection? #20
Check with one of the dealers on this one , If I'm not mistaken the driveline of a 226d is identical to your 1720d, in what case you should be able to order it from Yanmar. I don't know if you have a partsbook for your 1720, but I'm showing pn 194362-14610-x for the front tube and a 194362-14640 for the rear tube. There are also a couple of O-rings on each end pn 24321-000600 and a boot to connect the 2 tubes 194362-14650.
thanks Pete
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2023 UNVERFERTH 632 LOT NUMBER 179 (A53084)
2023 UNVERFERTH...
2001 CHEVROLET TOW TRUCK (A52472)
2001 CHEVROLET TOW...
KARCHER WALK BEHIND FLOOR SCRUBBER (A52472)
KARCHER WALK...
2014 Ford Taurus Sedan (A51694)
2014 Ford Taurus...
