Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it?
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it?
My basic under standing is $20,000 for hoe, $5000 for tractor, and then see if you NEED a skid steer or articulated loader. For track hoes I would look at 12-16 ton, Komatsu, Deere, Cat, and Hiatchi.
what about something like this? too big? is resale going to be more difficult?
Deere 790E LC Excavator $35000
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #22
I would go in the 12 to 16 ton range...But if the deal was right I would go bigger or smaller. Larger is much harder to move around (permits and such) and smaller will be a little slower. Like I said my 3.5 ton unit will take those stumps out and do your digging but on as large of a project as your looking at I would want something a little larger.
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #23
On the attachment. While it would help, I do not see it as necessary and I beleive any time saved would be lost but constantly changing from the ripper to the bucket.
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #24
According to Ritchie spec its a 25 ton model, which isn't necessarily bad. 161 hp is going to burn a lot of fuel, but get work done fast. I cant really comment on the price, that really is based on condition, demand, and distance to closest port. (Lots of old equipment shipped to Caribbean, Brazil, ect). Manual thumb is a big plus, hydraulic thumb is nice, but people have been clearing for a 100 years without them. Looks like good condition, and a good size to me. But for $35k I would want to take an equipment mechanic with me too look at it. Some leak down is ok, but will only get worse with time, make sure the turn table is good, and final drives. Ask if its ever had a hydraulic hammer on it, if so, the vibration takes a toll on every part of the actual hoe, from cylinders to arms, pins, ect
Expect to pay $500+$2/mile to move it
   / Front-end-loader backhoe unit - HOW can I get a bush hog cutter attachment on it? #25
I wanted a backhoe attachment when I bought my JD. Decided to just rent one a couple times a year when I needed it. It was the cheaper and easier way to dig.
4603 (A55272)
4603 (A55272)
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
LOT: (3) Sections of Steel Pallet Racking Welded Together: (1) 9' W x 9'H x 48" D, (1) 9' W x 7' ... (A59076)
LOT: (3) Sections...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
TUGGER TRAILER (A55745)
TUGGER TRAILER...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
