Front end loader control is stuck.
   / Front end loader control is stuck. #41
How does the vinyl guard come off? Tried to remove it and don't know how it fastened.
   / Front end loader control is stuck. #42
Page 11 in B7800 loader parts document shows the cover as part 290, looks like bolt 300 is what holds it on.
   / Front end loader control is stuck. #43
Thanks for your help. I will give 300 a try.
Do you have the same control valve on the 2710?
   / Front end loader control is stuck. #44
Yes, I had the same problem when mine was under warranty and the dealer came and fixed it in my garage. I wasn't home to watch, I assume they cleaned up the spring and balls and drilled a drain hole.
   / Front end loader control is stuck. #45
I have a question about the parts diagram.
Parts are assigned either a number or a letter on the diagrams.
Where do I find reference to the parts that have a LETTER designation?
   / Front end loader control is stuck. #46
Lettered parts are only available as part of an assembly, the assembly has a number. So for example on page 9 at the lower right on the page, the assembly #020 includes all the parts labeled A-J. So that means you can't buy part A by itself, you have to buy part #020, which includes the whole kitchen sink.
   / Front end loader control is stuck. #47
Thanks, that makes sense. Appreciate the help.
   / Front end loader control is stuck. #48
I have to remove the loader on my tractor.
Can I remove the cans on the loader control valve to clean and lubricate while the loader is off and the hydraulic lines are detached?
Do the parts (that I see in the diagram) come off the valve when I remove the cans? If so, how difficult is it to reinstall the inner parts
when the cans go back on?
Anything I should know regarding the removal and installation?
Looks like the cans are 1.25 in. SAE. I assumed Kubota tractors would require Metric tools??
   / Front end loader control is stuck. #49
You could make a video of the dissasembly.
Use the PDF to put things back together correctly
   / Front end loader control is stuck. #50
JJ-Can the cans be removed and cleaned with the loader off and hoses detached?
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
1988 KENWORTH T800 DUMP TRUCK (A58375)
1988 KENWORTH T800...
Peterbilt 377 Semi-Truck (A56438)
Peterbilt 377...
2023 SNORKEL A46JRT ROUGH TERRAIN BOOM LIFT (A59823)
2023 SNORKEL...
207282 (A52708)
207282 (A52708)
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
