Front end loader control is stuck.
   / Front end loader control is stuck. #51
I have to remove the loader on my tractor.
You might check for youtube videos that will help you, I found this one. Go to minute 4, the guy is taking the detent balls and springs out of his valve. There's probably better ones if you hunt around.
I also video things like this when I take them apart, then dump the video on my laptop so I can watch it while I do the reassembly.
   / Front end loader control is stuck. #52
Yes sir, that is correct.
   / Front end loader control is stuck. #53
Be careful, with the HUSCO valve the detent balls are a similar design with 4 balls energised by 1 larger ball with a spring behind it. Where you have to be careful is that when you remove the detent sleeve the balls have a tendency to "spring out". Just be careful you do not lose them. Make sure you lubricate them on reassembly.
   / Front end loader control is stuck. #54
It's been too cold to do this repair. If I were to carefully drill weep holes towards the bottom of the sleeves (while still assembled), will that damage anything?
Seems as if that might be easier than removing them??
   / Front end loader control is stuck. #55
I can not comment or condone this type of modification, however, I understand the problem. I am not exactly sure the internal configuration but if you take a look at the part number on the nametag I will be able to have a look.
   / Front end loader control is stuck. #56
You need to inspect the assembly anyway, so look for a weep hole or drill one when you have it dissembled.
   / Front end loader control is stuck. #57
My l5740 loader is stuck in for word position
Trailmobile Van Trailer (A56438)
Trailmobile Van...
Ford 8510 (A53317)
Ford 8510 (A53317)
CAT930K (A58214)
CAT930K (A58214)
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
20FT X 12FT LIVESTOCK SHELTER (A58214)
20FT X 12FT...
Friesen 240 Seed Tender (A59814)
Friesen 240 Seed...
