Grading Front Hydraulic Blade for Branson FEL
   / Front Hydraulic Blade for Branson FEL #21
Back slope near the top, where the holding type hook drops into or over
   / Front Hydraulic Blade for Branson FEL #22
Have a look at these hooks. I have had good luck with them this was.
   / Front Hydraulic Blade for Branson FEL #24
Pete, one inch in from the side and resting over the top. Franz
woohoo...finally a picture from Franz. That's exactly the way I was thinking of mounting mine...as the top ledge is just too narrow. Also , figured the edge had the most strength. So you just bolted them on and may tack them with a welder later. Now, I just need a picture from Jonathan to see how he did his. Thanks, Franz.
pete
   / Front Hydraulic Blade for Branson FEL #26
WOOHOOOOO! Im so excited about the picture. Its actually with a camcorder. I tacked them already and since this worked, Ill send more pictures later. Franz /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Front Hydraulic Blade for Branson FEL #27
Pete, I put a receive in the center of my bucket, on the same plate that my hooks are on. I put it here because its easier to see and hook up and move my trailers around the yard. I have in the past just used chains, but thanks to Jerry's post Im moving my trailers in a fraction of the time.... Thanks Jerry! I also designed and built a light bar today, Im leery of posting it yet because I think I can market the idea first. (real neat idea from a peanut) Im might buy lights tomorrow and I think that I will put feed to the tractors EXISTING front lights on a seperate switch and just use them as secondary lighting or transporting. The reason is so that I wont tax my alternator with lights that arent really positioned high enough. I'll send pictiures soon. /forums/images/graemlins/grin.gif
I kinda liked that reciever idea as well...you could have different kinds of hooks, balls, etc. You are right on the lights...the current front lights are pretty useless with the loader. I believe the alternator is not undersized...so 4 55w lights probably are OK. I will probably do a light bar later in the summer...hoping to get my lights mounted on the inside of the ROP. You can go to extremes, like the poster in CA who put about $1000 into strobe lights for his tractor.
I am going to have to learn how to weld. I have been inspired by everyone here that builds their own stuff.
sassafras
   / Front Hydraulic Blade for Branson FEL #29
What does sassafras mean?
   / Front Hydraulic Blade for Branson FEL #30
sassafras......
1. A deciduous eastern North American tree (Sassafras albidum) having irregularly lobed leaves and aromatic bark, leaves, and branches.
2. The dried root bark of this plant, used as a flavoring and a source of a volatile oil
Sassafras tea is the greatest /forums/images/graemlins/grin.gif
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2020 Toro Workman HD Gasoline Utility Cart (A50322)
2020 Toro Workman...
2018 FORD EXPEDITION (A51406)
2018 FORD...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
