Front loader hyd. bleeding procedure
   / Front loader hyd. bleeding procedure #1
Calbear55
California
Kubota B6000E
I finally got the B6000E for the church. Person who donated it went into the Hospital the day I went to pick it up:( had to wait a while longer. He had a hip replacement and that comes with a long recovery. He is doing very good for his age.
When I got the tractor over to the Church I changed the oils. I have air in the front loader hydraulic lines and have to bleed them. I was hoping someone could give me some guidance and let me know where to start:confused:
For a tractor that sat for several years(in a shed) it sure runs great. Donor told me he brought the B6000E when it was new in 1973. He only used this tractor for a small garden and in all the years it never left the yard. He gave me all the manuals but there is nothing about a bleeding procedure for the loader.
Thank you in advance- Craig
   / Front loader hyd. bleeding procedure #2
Cycling both functions of the loader from stop-to-stop will clear the air, there is no need to bleed any lines or cylinders. The system is self-bleeding.
   / Front loader hyd. bleeding procedure #3
Agreed.........Run it to the stops and the air will bleed back to the reservoir and be gone.:cool:
   / Front loader hyd. bleeding procedure #4
And then recheck your level. Done deal.
Thanks for all the replies:D. I was still having trouble with the loader being sluggish :mad:. I sat back and thought about it and realized the one thing I hadn't checked was the tension on the belt for the pump:eek:. Once I did the adjustment everything was okay:rolleyes:Again thank for your help!
2017 Yale GLC050VX 3,500 lb LPG Forklift  Powershift, Aux Hydraulics (A48561)
2017 Yale GLC050VX...
Veris 3-Point Soil Management System (A48561)
Veris 3-Point Soil...
2019 FREIGHTLINER CASCADIA DAY CAB (A45677)
2019 FREIGHTLINER...
John Deere 8320 Tractor (A47369)
John Deere 8320...
American Sanders Super 7R Electric Wood Floor Edger (A45336)
American Sanders...
SpotWeld RockerRite 480V Arm Type Spot Welder (A46683)
SpotWeld...
