Front loader hyd. bleeding procedure
   / Front loader hyd. bleeding procedure #1
Calbear55
California
Kubota B6000E
I finally got the B6000E for the church. Person who donated it went into the Hospital the day I went to pick it up:( had to wait a while longer. He had a hip replacement and that comes with a long recovery. He is doing very good for his age.
When I got the tractor over to the Church I changed the oils. I have air in the front loader hydraulic lines and have to bleed them. I was hoping someone could give me some guidance and let me know where to start:confused:
For a tractor that sat for several years(in a shed) it sure runs great. Donor told me he brought the B6000E when it was new in 1973. He only used this tractor for a small garden and in all the years it never left the yard. He gave me all the manuals but there is nothing about a bleeding procedure for the loader.
Thank you in advance- Craig
   / Front loader hyd. bleeding procedure #2
Cycling both functions of the loader from stop-to-stop will clear the air, there is no need to bleed any lines or cylinders. The system is self-bleeding.
   / Front loader hyd. bleeding procedure #3
Agreed.........Run it to the stops and the air will bleed back to the reservoir and be gone.:cool:
   / Front loader hyd. bleeding procedure #4
And then recheck your level. Done deal.
Thanks for all the replies:D. I was still having trouble with the loader being sluggish :mad:. I sat back and thought about it and realized the one thing I hadn't checked was the tension on the belt for the pump:eek:. Once I did the adjustment everything was okay:rolleyes:Again thank for your help!
1997 TRAILMOBILE 48X96 FLATBED TRAILER (A50854)
1997 TRAILMOBILE...
2021 Case Trident 5550 Spreader (A51039)
2021 Case Trident...
2011 INTERNATIONAL PROSTAR +122 6X4 DAYCAB ROAD TR (A51243)
2011 INTERNATIONAL...
2011 DODGE RAM 2500 (A50854)
2011 DODGE RAM...
Unused 2025 MX20R Mini Excavator (A49461)
Unused 2025 MX20R...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
