Front loader hyd. bleeding procedure
   / Front loader hyd. bleeding procedure #1
Calbear55
California
Kubota B6000E
I finally got the B6000E for the church. Person who donated it went into the Hospital the day I went to pick it up:( had to wait a while longer. He had a hip replacement and that comes with a long recovery. He is doing very good for his age.
When I got the tractor over to the Church I changed the oils. I have air in the front loader hydraulic lines and have to bleed them. I was hoping someone could give me some guidance and let me know where to start:confused:
For a tractor that sat for several years(in a shed) it sure runs great. Donor told me he brought the B6000E when it was new in 1973. He only used this tractor for a small garden and in all the years it never left the yard. He gave me all the manuals but there is nothing about a bleeding procedure for the loader.
Thank you in advance- Craig
   / Front loader hyd. bleeding procedure #2
Cycling both functions of the loader from stop-to-stop will clear the air, there is no need to bleed any lines or cylinders. The system is self-bleeding.
   / Front loader hyd. bleeding procedure #3
Agreed.........Run it to the stops and the air will bleed back to the reservoir and be gone.:cool:
   / Front loader hyd. bleeding procedure #4
And then recheck your level. Done deal.
Thanks for all the replies:D. I was still having trouble with the loader being sluggish :mad:. I sat back and thought about it and realized the one thing I hadn't checked was the tension on the belt for the pump:eek:. Once I did the adjustment everything was okay:rolleyes:Again thank for your help!
2014 Doosan DL250-5 Articulated Wheel Loader (A49346)
2014 Doosan...
3/4 Electric Drill (A50860)
3/4 Electric Drill...
2013 Ford F-350 4WD Pickup Truck (A50860)
2013 Ford F-350...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A50397)
80in HD Tooth...
2007 Dodge Nitro 4x4 SUV (A48082)
2007 Dodge Nitro...
2 Yard Commercial Dumpster (A49346)
2 Yard Commercial...
