front plow and rear blade
   / front plow and rear blade #11
I like using both the front plow and rear blade for snow. Problem is the rear blade doesn't add enough ballast to counter the front plow. What's a good way to add weight to the rear? I do have loaded tires.
I'm not understanding this. You want to use both blades at the same time? You want to push better when using just the front blade? When you say "counter" the front plow do you mean directional control when the front is angled or are you slipping and losing traction?
   / front plow and rear blade #12
Thats one reason I got the bigger tractor. More weight( 10,100# across the grain scales) and I can bust frozen berms with my rear blade and don't need chains or using a 3-point blower.
I finally realized I don't understand what Chuck wants to do either. Use front plow & rear blade at the same time or one or the other independently.
I primarily use the front snowplow, but I often use the rear blade to clean up tight spots. I generally push with the rear blade and I have lots of control. I have to sneak by parked cars and wood piles. I love the loaded ag tires for snowplowing. I normally have no problem, but have experienced some slight fishtailing at times. I know some rear ballast would help. I'm probably just looking for the perfect setup, if that's possible.
   / front plow and rear blade #14
I primarily use the front snowplow, but I often use the rear blade to clean up tight spots. I generally push with the rear blade and I have lots of control. I love the loaded ag tires for snowplowing. I normally have no problem, but have experienced some slight fishtailing at times. I know some rear ballast would help. I'm probably just looking for the perfect setup, if that's possible.
I totally understand what you are doing.
I don't have any pics, but I welded two bolts on top of my blade frame, pointing upward head down, between the 3pt tower and the angle pin. I then lay two suitcase weights over the bolts, stacked on top of each other, laying flat on top of the blade beam. Adds 250lbs to the blade. Build could be altered to fit your application.
   / front plow and rear blade #15
So when the rear blade is down, you are scooting over (fishtailing) when you use it to push? Putting weights on the rear plow would only help when the rear blade is up as far as tractor control. You would need either wheel weights or chains. I have chains on my ags. They make it a different tractor traction wise. You think you don't need them but you end up kind of surprised what they do for the tractor. I'm pretty happy with this set up. The bigger the tractor, the bigger the implements but you can run into the same problem as loads increase that the bigger tractor can muster over the smaller one. Chains would cure your problem. I leave mine on all the time.
   / front plow and rear blade #16
My understanding is that he's losing traction when the front blade is being used, and the rear is in the air. Well, that's the situation in which rear ballast might help. As you say, the ballast isn't going to do anything with the blade on the ground. I'm speculating here, but I would imagine that when you're using the front blade, the front tires are gonna get pushed out of line, not the rear. So, maybe i don't understand what the OP is trying to fix. I agree with everyone about the chains though. I run them just on the front tires of my snow removal tractor (TC29D with 7' rear blade), and it makes a huge difference in steerability.
   / front plow and rear blade #17
I’ve had the best luck putting the extra traction on the axle that is closest to the snow plow. IE- front blade=front chains. Rear blade=rear chains
   / front plow and rear blade #18
If your front plow is "fixed" and doesn't float(like a truck plow) it will take the weight off the front and be difficult to steer so counter weight will not help in this situation.
   / front plow and rear blade #19
" I generally push with the rear blade and I have lots of control"
I found BIG differents when it came to pushing w/rear blade than pulling...much better traction pulling and easier on 3 pt. hitch.
   / front plow and rear blade #20
I built a smaller truck plow with a SSQA for my L3200. Ran it and the LandPride back blade for a bit. Ended up selling the back blade as it didn't give me anything over the front blade. Ended up getting a 3pt blower for heavy snow. I plowed 85% of the time still as it was faster & didn't kill my neck. Still needed the blower for drifts, windrows & stuff.
Chains on the front got steering back while plowing & increased my push 20% or so. Rear chains wouldn't fit without wheel spacers.
Upgraded to my new L4060 for the cab, but there was no snow worth plowing last winter.
Giyi 72" Grapple Bucket (A57149)
Giyi 72" Grapple...
2022 Belgrade Steel 350 Barrel 65 Ton T/A Towable Cement Silo (A56857)
2022 Belgrade...
2020 CATERPILLAR 299D3 SKID STEER (A52709)
2020 CATERPILLAR...
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
2321 (A58376)
2321 (A58376)
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A56129)
2000 GMC C7500...
