Front tires caused axle failure...?
   / Front tires caused axle failure...? #61
Dang I guess every tractor out there in the world with smaller front tires is going to destroy it's self seeing as almost anyone that does enough hours and work on them will wear out the smaller fronts faster then the rears. Then on top of that I can vary the loaded radius depending on weather a load is being carried for transport or pulled to work, a heavy tongue load will lift the front increasing the front loaded radius and squat the rear decreasing the loaded radius which is a considerable change in the lead lag effect.
I would bet that in some cases that the effect is so gradual (like with the the wear of tread etc.) that any damage could be self canceling by wearing any binding parts equally... I've a seen a number of posts where owners report ground metal in their gear oil without any symptoms or apparent problems...
In post #5 I related a simple way to actually test and see if the lead-lag is possibly causing a future problem...
Obviously there is some measure of forgiveness beyond the ability of ground breakup under the bind...but whether you want to recognize it or not the lead-lag is there and it can/will cause damage...If it were not a fact it would not be acknowledged by manufacturers and cited in operator manuals etc. and be typically common knowledge among experienced operators...most of the folks on TBN are aware of the fact...it's not like it's a myth...!
BTW...if you want others to take you more seriously when it comes to general knowledge you should learn the difference between terms like "it's self" and itself....FYI "it's" is a contraction for "it is" just sayin...:D
   / Front tires caused axle failure...? #62
Thanks for the spelling lesson :shocked:
   / Front tires caused axle failure...? #63
The smaller tires on front is geared in sync with the larger rear tires on tractors, therefore when I have AG 11.2-24 on the rear and 7-16 on front, going down to a 15" or up to 17" on front will throw the front gearing speed out of sync and forces more wear on the drivetrain, the same with pickup trucks, if a 4x4 came with 18" tires your put the same size on front and rear and preferably the same brand.
Right tire size is everything for the designed gear ratio on a 4x4 tractor and further more you shouldn't put two different size tires on the rear end either, it will increase wear&tear and cause you to go in circles.....
What kind of help did you ask for, they should've given you tire size specs with tire options.
They just sent me tire R1 R4 and Turf tire sizes listed in the manual, while ignoring my whole question about the 15x19.5 tires.
Did they start leaking oil before the catastrophic failure? When my L5740 started leaking oil onto the inside of the rims, I checked here and found it not unusual when doing a lot of loader work like load and carry. As I caught it early, no damage other than failed bearings. My dealer said he has one customer who brings the drives into the dealership as they fail (yes, it is that frequent). They replace the bearings, he reinstalls and goes on.
The axle shaft is like a lever working on the bearings. If the center of the wheel is over the midpoint of the bearings, the bearings are loaded equally. Widen the tire and that load line moves away from the midpoint. If it痴 outside the outer bearing, the outer bearing is handling all the load designed to be carried by 2 bearings. Move the load point out further and the outer bearing is loaded even more than the weight carried by the wheel due to leverage. Bearing life is a factor of the cube of the load so just a little shift causes a large reduction in bearing life.
Your tire radius difference is insignificant. Your tire width is very significant. But the tractor went 3600 hours before failure. I do realize that part of those hours were with the standard size. If you replace the bearings before they fail to the point that they damage the gear, you can keep using the wide tires. Kubota uses that style final drive on the front in order to get a tight turn radius. My M7 has much wider fronts than the drive tires on my L5740. To make it work the M7 has a different style final drive - a planetary - and the turn radius is a country mile. But it can withstand the load. However it is not robust enough to use duals on the front like you see on so many over 250 HP tractors.
The following is an excerpt from diagnosing failures like yours:
Increased Offset Most oversize tires are on wheels that are offset so the tires don稚 rub. This moves the load on the bearing to the outside, so the load on the bearing is no longer centered.
Increased Leverage A larger tire is a longer lever. A heavier tire puts more force on the lever. A long lever with more force behind it puts greatly increased leverage on the bearing and hub.
There was no oil leaking from the hubs prior. Maybe I'll take a peak at the other side bearings
   / Front tires caused axle failure...? #65
I am well aware of how tractors are geared differently in the front and rear ratios to hopefully have the desired 3-5% lead in the front compared to the rear with the designed height (loaded radius) on them. The loaded radius is the determining fact on how the tires work you can change rim diameters and tire profiles and maintain the proper tire ratios it is done quite often for many different reasons.
   / Front tires caused axle failure...? #66
Did you change the front size without changing the rear size to.............Maybe a local dealer would be more helpful. I looked up Kubota m5400 on Tractor Data and dont show that size for some reason>4WD Standard tires (ag):>Front: 9.5-22. Rear: 16.9-28.
TractorData.com Kubota M54 tractor dimensions information
But on the other hand Tractor Data shows different tire options for my L3400>> TractorData.com Kubota L34 tractor dimensions information
AA year after I bought my tractor with AG tires I didn't like how they sink in soft ground so quick and ask the dealer if I could change the fronts from 7-16 to the wider Industrial tires, they said sure long as I change the rears to which meant changing to all 4 different rims, but then my rear chains wont fit and bla bla bla, from what I know you change one thing then 15 other things have to be changed, domino effect............
   / Front tires caused axle failure...? #67
Dang I guess every tractor out there in the world with smaller front tires is going to destroy it's self seeing as almost anyone that does enough hours and work on them will wear out the smaller fronts faster then the rears. .
Maybe I didn't read it right but your former post suggest different to me, I have smaller front tires on my compact tractor and it's hardly ever in 2 wheel drive, actually thats what it really is because of the open differentials front and rear.
   / Front tires caused axle failure...? #68
Seems there are many four wheel drive tractors out there that do last for a long time if conformed to the manufactures specifications.
Put an inordinately wide front tire on causes stress on the axle imposed by differential forces when turning. The inside of the of the tire cover very less distance than the outside of the tire does. Creates stress! Pretty simple.
   / Front tires caused axle failure...? #69
I think you mean Rolling (loaded) Circumference rather than Loaded Radius. LC is for calculating lead/lag ratios. LR is for ground clearance.
The confusion comes about because in one special case - that being for a perfect circle - radius & diameter are related to circumference by pi. But that's not the case for a loaded tractor tire.
   / Front tires caused axle failure...? #70
No I meant the loaded radius, the loaded circumference can be calculated from the loaded radius. The loaded radius is easier to measure with a stationary tractor.
The loaded radius is affected by load and tire pressure which in turn affects the loaded rolling circumference.
The taller the sidewall of a tire the more loading and pressure can effect those values.
When you get into taller tires it can easily be seen how inflation affects loaded radius or loaded rolling circumference,
You can reduce or increase the lead lag ratio by varying tire pressure, with a radial 30" or larger tire the loaded radius can change by a half an inch.
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
2014 Ford F-550 4x4 Terex Hi-Ranger LT-40 40ft Insulated Bucket Truck (A55788)
2014 Ford F-550...
New JMR Mini Skidloader 40" Grapple (A50775)
New JMR Mini...
2019 Bobcat 3400 4x4 Utility Cart (A55851)
2019 Bobcat 3400...
