rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,682
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
No I meant the loaded radius, the loaded circumference can be calculated from the loaded radius. The loaded radius is easier to measure with a stationary tractor.
The loaded radius is affected by load and tire pressure which in turn affects the loaded rolling circumference.
The taller the sidewall of a tire the more loading and pressure can effect those values.
When you get into taller tires it can easily be seen how inflation affects loaded radius or loaded rolling circumference,
You can reduce or increase the lead lag ratio by varying tire pressure, with a radial 30" or larger tire the loaded radius can change by a half an inch.
How would you go about calculating the rolling circumference from a loaded radius? I'm willing to believe that it can be done, and the more I think about it the more I would like to learn more about it.
First things first.... I am using the term "loaded radius" to be the vertical distance from the center point of the axle to the surface of the ground. That distance is basically ground clearance. It will vary with load as the tire squats, but will remain constant as long as the load doesn't change. And part of the tire is flat against the ground.
So a bug crawling around the circumference of that tire would be traveling in an ellipse with one flat area. The distance he crawls around that ellipse plus the length of the flat area against the ground is the "rolling circumference".
I'm naturally lazy, and have never really got down and worked out a formula complex enough to solve the relationship between a changing radius and the resulting circumference. You see that sort of thing in orbital math where the distance an object moves in a path can be calculated in spite of the fact that the path is elliptical. So the path of an ellipse is a solvable relationship, especially if we ignore the flat spot where it meets the ground and the fact that the ellipse changes with load and pressure.... although it's getting ugly....
To keep things simple, I'd probably do what the manufacturers do and say that the formula only works for one specific tire at one pressure. That's how they give both static loaded radius and dynamic rolling circumference in their specs. So there's a relationship, but it sure isn't pi. My bet is it is just an average relationship that only works for their tires over a small range of loads and pressures.
Of course there is a simpler way. You can always measure to create specs. It may be that manufacturers measure both rolling circumference and loaded radius instead of trying to calculate one from the other. That's what I do. Then there's no need for some exotic formula. Measuring is easy to do and always right.
rScotty
