front winch powered by PTO
   / front winch powered by PTO #11
There are a lot of adequate pumps that take a max of 3600 RPM so depending on the pump, a direct drive link at 2500 should work...almost all of the pumps I looked at have higher GPM ratings than the tractor's native system...
not sure what would be required to make the direct drive link from PTO shaft to pump shaft...hopfully just a splined sleeve and a machined bushing??
Ok, I get it. I was thinking something like these which run at 540 or 1000 rpm.
https://www.surpluscenter.com/sort.asp?search=pto pump
Just make shure the pumps capacity does not exceed the available horsepower.
I have a lot to learn about the hydraulic end of this...
...2500RPM sounds a little high-most Mid-PTO's are usually 2100 RPM...
I just double checked and 2500 is what the original Kubota decal on the PTO control lever says...?
it would add a little to the expenses and involve more fab work but it would not be that difficult to us a chain and sprockets to adjust the RPMs?
I'm hoping to find something like one of these...I saw one that was min. 2000 RPM/max 5000...like I said I have a lot to learn about hydraulics...
https://www.surpluscenter.com/sort.asp?UID=2009040819515543&catname=hydraulic&keyword=HPSR
   / front winch powered by PTO #14
I drive a pump from the crank (FRT pto) on my Mitsu for the FEL. Works just great!
My buddy also has a frt PTO driven pump for his FEL on a B7100
In bosthcases the result is faster FEL movement over engine pumps.
My FEL when coupled to Mitsu engine pump was painfully slow and now I almost operate like a bobcat.
About only requirement is a U-joint for proper alignment followed by required valves and plumbing.
With our FEL's one post was designed to be a reservoir with appropriate fittings.
   / front winch powered by PTO #15
I have an 8000lb hyd winch mounted permanently in my loader frame. It is the one handiest thing I ever did to a tractor. Seems as I use it a lot for picking attachments, moving logs and such. I don't use it for logging as I have one for the rear also. Is nice to always have that cable handy.
It has saved me twice, I can't tell you how many others it has saved, lots.
I do need to replace the fairlead up front, will put up a pick.
Bobcat 435 FastTrack (A60462)
Bobcat 435...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2003 International 9200I (A53317)
2003 International...
24in pin on excavator tooth bucket (A56438)
24in pin on...
3-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
3-Gang Reel Mower...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
