Frontier 72" snowplow on a 200cx (2320)
   / Frontier 72" snowplow on a 200cx (2320) #11
I guess my experience with FEL snowplows is different. I built one and have used it for 3 seasons. I have had none of the problems mentioned. Granted, I have not had any snowfalls over 10", but my tractor seems to handle that fine! My blade is 60", and I designed a way to allow the blade to float or to apply down pressure. I agree with everyone who says the plow is too far forward- that is the only thing I would change if I built mine again. I like the ability I have to "lift" the snow. :) Just my opinion, but I don't want a frame mounted blade as long as my setup works well.
Here is the link to my plow with pictures:
http://www.tractorbynet.com/forums/attachments/69523-fel-snowplow.html
   / Frontier 72" snowplow on a 200cx (2320) #12
I had one of these plows and though it moved the front end of my 3720 around. This plow is much too heavy for any of the 2000 series machines. It is made of lead and would stress the frame, loader arms and drivetrain to use it. You might be able to get away with it but it is just not worth the potential damage to the machine. I have found these wide blades just do not do that great a job in snow. One does not need a heavy blade for snow. My Gator, with a 72" snow blade that weighes only 90## is superior to any tractor mounted blade I have tried. I found my old 595 with a 54" front blade to be 90% as fast as my 3720 with a 72" blade secondary to its manuverability.
John M
   / Frontier 72" snowplow on a 200cx (2320) #13
My experience has been different. Since I plow dirt roads I wouldn't want anything lighter. I plow in 6th or 7th gear with my 790 and have recently put on wings to widen the blade. I will see how that works this winter. I've never had my front end pushed around very much but have lifted the front wheels off the ground if I try to float the blade on uneven ground. I do have filled R1 tires and am always in 4WD in the snow. I've only had it for a year so haven't really done snows over about 18". It is also harder to turn on the narrow roads since it does make my tractor a lot longer. At this point I am very happy with the frontier blade.
   / Frontier 72" snowplow on a 200cx (2320) #14
What's the ballpark price on the Frontier 72" snowplow?
   / Frontier 72" snowplow on a 200cx (2320) #15
Hi All,
I don't have a 72" Deere blade for my 2520 but I would love to try one. I have a 60" Curtis loader plow that I use for a 450 foot paved driveway that has 4 turns and is sloped. (I'm on the side of a mountain, it's not a gentle slope) I also use it to clear the front lawn to park the cars while I plow the driveway, the road around back and paths from the house to the woodshed. I have used it for the snowiest on record in NH, in anything from a dusting to 1" of slush to 2+ feet of heavy wind blown snow with 3 and 4 foot drifts.
My Curtis weighs far more, hangs out farther and sits higher than the Deere setup. I can take full passes with it, I can bank the snow, I can push the banks back. In short, it works. Is it perfectly matched to the 2520 and 200cx? No, not at all. Is it better that a walk behind Ariens? Yep, by a couple miles.
Pros:
Fast, I can plow in high in snow less than a foot deep
Rugged, it's built like a tank
Easy to swap out with a bucket
One tool for both plowing and banking
Cons:
It's heavy
It has leverage over the loader
It leaves little rust lines from the shoes
It's easy to roll up unfrozen grass and to wack the house/barn when turning. (don't ask how I know these things)
It's not green :rolleyes:
One of the issues stated here is that too big of a blade will push your tractor around and yu'll loose steering, yep, if you try to go uphill making a full cut, you will get that every time if you float the loader. Simple solution, pick up the blade about 1/2 inch, 700 Lbs hanging off the loader arms puts a lot of weight on those front wheels. Another way is to leave the cement filled ballast box off the tractor if you have loaded tires, no weight off the back picking up the front. Another complaint is that you loose steering and have to use steering brakes, isn't that what they are there for? That's how I was shown how to use them.
Is it better than a front blower? for me, yes. For you? only you can answer that. Would I buy the 60" Curtis again? No, I would go with a wider blade, maybe 66 or 72. The 60 is just a wee bit small when angled and going around corners. Would I trade for a 72" Deere setup? In a heartbeat. In my poor slobs opinion, it's better to have a little too wide than a bit too narrow.
Last year I plowed with no chains, empty tires and a cement ballast box and had no issues. Did it slip a little? yep, when it got cold and ice formed on the driveway, other than that, not an issue with 4wd. This year I have 4 link chains, loaded tires and a 60" Meteor blower for the back, I have become the snow destroyer... :D
a bit long but still only 2 cents,
Tom
   / Frontier 72" snowplow on a 200cx (2320) #16
I think mine was about $1500. The angle hydraulics was another $300 + hoses + valve + Quick Disconnects + Power Beyond. Here is a link to the JD website on the blade.
John Deere: Features for Boom Mounted Front Blade
My driveway is a shelf road where I can push all the snow off one side so a blade is a very good solution for me.
   / Frontier 72" snowplow on a 200cx (2320) #17
For plowing snow I use a rear ballast of about 200 lbs with chains on the rear, rear tires are not loaded.
Too many people get carried away with the rear ballast weight. More weight is not always better. As stated above, effectiveness of the 4WD is diminished quite a bit with too much weight on the rear and not enough on the front. Amazing what lifting the font blade just off the ground will do for front traction.
   / Frontier 72" snowplow on a 200cx (2320) #18
I have had:
  • A frame mounted blade on my 4100
  • a boom mounted blade on my 4310
  • a frame mounted blade on my current 3520
Sofar, i must say the frame mounted blade worked better for me. I have yet to try it out on my 3520, but based on past experience the frame mounted blade worked better for me.
   / Frontier 72" snowplow on a 200cx (2320) #19
Went the boom mount, used once. I'll stay with the frame mount thank you very much.
   / Frontier 72" snowplow on a 200cx (2320) #20
I don't think there is any doubt the frame mount is better, but the boom mount is much easier and quicker to mount. I had no complaints about the boom mount blade, but specifically for snow, it and my tractor were not as good as my Gator, nor as fast. If I were doing some dirt or gravel, yes. I also found the cumbersome blade difficult to store when not in use and really too heavy to easily stand up, although it could be done. The blade did cause a great deal of moving in the front end unless the snow was most powdery or the blade was just perfectly leveled, or I took smaller "bites." But then, one loses the benefit of a wider blade.
John M
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
2016 CATERPILLAR 325FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2007 Ford Expedition EL Limited 4x4 SUV (A53424)
2007 Ford...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
UNUSED LANDHONOR LHR-SP50 HYD SHOP PRESS (A54757)
UNUSED LANDHONOR...
2013 BMW X5 xDrive35i AWD SUV (A53424)
2013 BMW X5...
