Frozen Nuts
   / Frozen Nuts #1
Dave01
NH
Sorry for the title! I'm having a hard time getting the blades off my 48GT deck, I haven't had them off since I bought this tractor last fall. I've struggled before with deck nuts but have always been able to loosen things up, but not this time. I've sprayed with Break-Away penetrating oil twice a couple days apart, have tapped to set up vibrations, am using a 1 1/8" box end wrench, have tried hitting the wrench with a hammer, can't get any of the 3 nuts to budge.
I don't have an impact wrench, any other tricks I could try?
   / Frozen Nuts #2
If you have the deck off then I would use a torch to heat the nuts. Even a propane torch should supply enough heat to loosen the rust bond. Also a breaker bar and a 6 point socket would be good.
   / Frozen Nuts #3
Hey Dave,
I'm a big fan of a product called PB Blaster, it's a penetrating oil type solution.
That and an impact driver.
They make pretty powerful batter operated impact drivers now (Dewalt), maybe you could rent one, or take the deck to a garage and have them loosen them for a couple bucks?
A torch applying some heat will usually free them up too, most people don't have torches.
Curt
   / Frozen Nuts
I've got a propane torch, I'll heat it up and see what happens.
   / Frozen Nuts #5
You might also check to see if a neighbor or friend might let you borrow a 3/4" drive socket set - that's what I use on my 48" deck blades (not too expensive at TSC or Harbor Freight).
Nittany
CC 2518 w/48" deck
   / Frozen Nuts #6
Try pinemountainman's wax trick on this this thread
   / Frozen Nuts #8
A decent air impact wrench should buzz those right out.
   / Frozen Nuts #9
A impact gun is the ideal way to get them off. If you don't have one try the wax trick that gator directed you to in the other thread. It has worked for me numerous times over the years.
   / Frozen Nuts
I hope they're not left hand threads, would be a first for me on mower decks!
I'll be trying the wax trick tomorrow, that sounds pretty neat. Thanks for all the good suggestions.
2019 Ligchine Spiderscreed Concrete Screed (A55851)
2019 Ligchine...
2022 CATERPILLAR 289D3 SKID STEER (A52707)
2022 CATERPILLAR...
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
Year: 2014 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A56859)
Year: 2014 Make...
7' DRAG HARROW (A57192)
7' DRAG HARROW...
202474 (A54757)
202474 (A54757)
