Frozen throttle cable
/ Frozen throttle cable #1
mbohuntr
Platinum Member
Upstate NY
Mahindra 1533
Mornin everyone, -3F here... My throttle cable must have some water in it, and sticks until the engine warms it up. Any suggestions on getting it out? WD-40?
Thanks!
Mike
/ Frozen throttle cable #2
Or this CRC 6-56 Multi-Purpose Lubricant
/ Frozen throttle cable #4
WD40 start,heard of some using brake cleaner spray before.
/ Frozen throttle cable #5
Hi proof alcohol or "Heat" from a can when tractor is warmed up....The alcohol will get rid of moister.
The key is to get in inside, and look for any low spots in the line where it may collect.
/ Frozen throttle cable #7
Move someplace warmer? Put the wife’s car outside and the tractor inside?
/ Frozen throttle cable #8
Antifreeze some times will work to loosen / unfreeze, frozen cables
Isn't that corrosive on steel?
I filled it with rubbing alcohol several days ago, and tomorrow I am going to pump it full of fine machine oil so at least it should bond to the cable and not allow the ice to grab it.....
We had a 2 day thaw, and now it is near the single digits again... IT WORKED! Cable nice and free!
/ Frozen throttle cable #13
What I did was to cut a piece (8-12 inch) of clear tubing and slide it on the end of the throttle cable at the engine end, then clamped it on with a hose clamp. I then filled it with Isopropyl alcohol (99%) then using compressed air I blew it into the cable. Rinse repeat. So far the problem has not come back.
I'll have to remember those ideas, thank you!
/ Frozen throttle cable #16
I think with the rust and corrosion inhibators they put in to protect your engine and radiator it wouldn't be an issue. But it was just a thought and method that I was told by an old timer that works pretty well.
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A61307)
2023 Kubota...
Vermeer Vac trailer (A60352)
Vermeer Vac...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
