6075 cab issues since new.
/ 6075 cab issues since new. #1
steve stiller
Have a 6075 cab model. Had to dealers a few time and got back again. Kicks pto out on regular540 when you make a turn or go over something that isn’t smooth. SDs crazy but if you keep it in straight line stays in gear when you turn it seems you take power off for turning split second it kicks pto out of gear. This has happened ever since new. They said linkage and oiled and adjusted both times and tractor still the same. Tractor is new roughly 100hrs. I don’t farm and bought it mainly to move things around with forks/bucket. Also I just idle around 1000-1200rpms 99% of time. When I mow at 540rpm after 1/2 hr getting motor hot motor kicks down to 1600rpm and rpm’s won’t increase no matter where throttle is won’t rev up. Thanks for any insight on this
/ 6075 cab issues since new. #2
I have a Mahindra 4510 and it used to get hot when mowing. Removed the side panels and it runs much cooler.
Tractor isn’t running hot at all. Just after about 1/3-1/2hr of mowing rpm’s cut down to 1600ish rpm from the 540rpm to run mower. So I got to cut in low range 1st or 2nd gear with 7 foot flair mower. I normally cut in mid range 3rd gear and never bogged rpm’s down.
/ 6075 cab issues since new. #4
Steve I would think the dealer should be able to fix that problem, have you thought about putting a little bit more pressure on him to fix.
I have a 2660 cab it a tym built with a Mahandra engine no regin it took a while for me to get used to the auto clutch but now i really like it now.Hopefully your Dealer will help you out.
