fuel additives
   / fuel additives #11
Not any more. Used to run additives and/or premium diesel in the very early days but came to realize that, just as lube oil needs no help with additives, neither does the fuel.
Tens of thousands of gallons burned without additives...no problems, either.
   / fuel additives #13
Power Service in every tank of diesel fuel is the only additive I use in my Kubota. When I had the Ford 8N I would add a little Marvel Mystery Oil to every tank of gasoline. I don't know if it helped the tractor as much as it helped my mind thinking I was doing the engine some good.
I do know that Power Service is supposed to help keep the fuel delievery sytem cleaner and help with getting rid of water in the fuel, which is a good thing.
I wonder if the cleaner burning diesel fuels that are coming will require some attitive for the older diesel engines like unleaded gasoline did for older gas engines?
Randy
   / fuel additives #14
HomeBrew2 said:
Ok, I'll bite, what the heck is "premium diesel" ?!
Premium diesel usually has a higher cetane rating than regular diesel. Sometimes it has additives. My distributor sells dyed premium diesel as his off-road offering. Cetane ratings for premium diesel are usually in the uipper 40's (47-49).
   / fuel additives #15
You could have saved yourself some money by adding mineral spirits, which is the primary ingredient in MMO. If I recall correctly, 98% of MMO is mineral spirits.
   / fuel additives #16
Mineral spirits? Yes... it has some. 98% not even close.
MARVEL OIL -- MYSTERY OIL
MATERIAL SAFETY DATA SHEET
NSN: 915000F003957
Manufacturer's CAGE: 95015
Part No. Indicator: B
Part Number/Trade Name: MYSTERY OIL
General Information
Company's Name: MARVEL OIL COMPANY INC
Company's Street: 331 N MAIN ST
Company's City: PORT CHESTER
Company's State: NY
Company's Country: US
Company's Zip Code: 10573-3305
Company's Emerg Ph #: 914-937-4000
Company's Info Ph #: 914-937-4000
Record No. For Safety Entry: 002
Tot Safety Entries This Stk#: 002
Status: FE
Date MSDS Prepared: 16FEB93
Safety Data Review Date: 31MAY95
Preparer's Company: MARVEL OIL COMPANY INC
Preparer's St Or P. O. Box: 331 N MAIN ST
Preparer's City: PORT CHESTER
Preparer's State: NY
Preparer's Zip Code: 10573-3305
MSDS Serial Number: BXKDX
Ingredients/Identity Information
Proprietary: NO
Ingredient: MINERAL OIL, PETROLEUM DISTILLATES, SOLVENT-REFINED HEAVY
NAPHTHENIC DISTILLATE
Ingredient Sequence Number: 01
Percent: <75
NIOSH (RTECS) Number: PY8040000
CAS Number: 64741-96-4
Proprietary: NO
Ingredient: MINERAL OIL, PETROLEUM DISTILLATES, SOLVENT-DEWAXED HEAVY
NAPHTHENIC
Ingredient Sequence Number: 02
Percent: <75
NIOSH (RTECS) Number: PY8038000
CAS Number: 64742-63-8
Proprietary: NO
Ingredient: STODDARD SOLVENT (PETROLEUM DISTILLATE), MINERAL SPIRITS
Ingredient Sequence Number: 03
Percent: <30
NIOSH (RTECS) Number: WJ8925000
CAS Number: 8052-41-3
OSHA PEL: 500 PPM
ACGIH TLV: 100 PPM
Other Recommended Limit: 525 MG/***
Physical/Chemical Characteristics
Appearance And Odor: REDDISH VISCOUS LIQUID W/HYDROCARBON ODOR.
Boiling Point: 341.6F
Vapor Pressure (MM Hg/70 F): 5
Specific Gravity: 0.83
Solubility In Water: UNSOLUBLE
pH: 6.3
Fire and Explosion Hazard Data
Flash Point: 174F
Lower Explosive Limit: 0.9
Upper Explosive Limit: 7
Extinguishing Media: FOAM, DRY CHEMICAL, CO2
Special Fire Fighting Proc: USE WATER TO COOL EXPOSED CONTAINERS. IF
LEAK/SPILL HASN'T IGNITED, USE WATER TO DISPERSE VAPORS & PROVIDE
PROTECTION FOR MEN ATTEMPTING TO STOP A LEAK.(SUPP)
Unusual Fire And Expl Hazrds: VAPORS ARE >THAN AIR & MAY TRAVEL ALONG
GROUND/BE MOVED BY VENTILATION & IGNITE BY HEAT/PILOT LIGHTS/OTHER IGNITION
SOURECES DISTANT FROM HANDLING POINT.
Reactivity Data
Stability: YES
Cond To Avoid (Stability): HEAT, SPARKS, FLAME
Materials To Avoid: STRONG OXIDANTS
Hazardous Decomp Products: CO2, CO
Hazardous Poly Occur: NO
Conditions To Avoid (Poly): CONTACT W/SKIN.
Health Hazard Data
LD50-LC50 Mixture: ORAL LD50 (RAT): 5 G/KG
Route Of Entry - Inhalation: NO
Route Of Entry - Skin: NO
Route Of Entry - Ingestion: NO
Health Haz Acute And Chronic: SKIN: PROLONGED/REPEATED CONTACT W/PRODUCT
TENDS TO REMOVE SKIN OILS, POSSIBLY LEADING TO IRRITATION & DERMATITIS.
EYES: MAY CAUSE IRRITATION. PRODUCT HAS A LOW ORDER OF ACUTE ORAL & DERMAL
TOXICITY, BUT MINUTE AMOUNTS ASPIRATED INTO THE LUNGS DURING INGESTION/
VOMITING MAY CAUSE MILD TO SEVERE PULMONARY INJURY.
Carcinogenicity - NTP: NO
Carcinogenicity - IARC: NO
Carcinogenicity - OSHA: NO
Explanation Carcinogenicity: NONE
Signs/Symptoms Of Overexp: IRRITATION
Emergency/First Aid Proc: EYES: FLUSH W/CLEAR WATER FOR 15 MINS. SKIN: IF
INJECTED INTO/UNDER/ANY PART OF BODY, REGARDLESS OF APPEARANCE OF THE
WOUND/SIZE, PERSON SHOULD BE EVALUATED IMMEDIATELY BY PHYSICIAN AS A
SURGICAL EMERGENCY. EVEN THOUGH INITIAL SYMPTOMS FROM HIGH PRESSURE
INJECTION MAY BE MINIMAL/ABSENT, EARLY SURGICAL TREATMENT W/IN FIRST FEW
HOURS MAY REDUCE THE ULTIMATE EXTENT OF INJURY. (SEE SUPP)
Precautions for Safe Handling and Use
Steps If Matl Released/Spill: RECOVER FREE PRODUCT. ADD SAND/EARTH/OTHER
SUITABLE ABSORBENT TO AREA. MINIMIZE SKIN CONTACT. KEEP OUT OF SEWERS &
WATERCOURSES BY DIKING/IMPOUNDING.
Waste Disposal Method: PREFERRED METHOD IS INCINERATION. DISPOSE OF IAW/
FEDERAL, STATE & LOCAL REGULATIONS.
Precautions-Handling/Storing: KEEP CONTAINERS CLOSED WHEN NOT IN USE.
DON'T STORE NEAR HEAT, SPARKS, FLAME/STRONG OXIDANTS.
Other Precautions: AVOID PROLONGED/REPEATED CONTACT W/SKIN.
Control Measures
Respiratory Protection: USE SUPPLIED AIR RESPIRATORY PROTECTION IN
CONFINED/ENCLOSED SPACES, IF NEEDED.
Ventilation: LOCAL EXHAUST: TO CAPTURE VAPOR/MIST/FUMES IF NECESSARY.
MECHANICAL (GENERAL): ACCEPTABLE.
Protective Gloves: HYDROCARBON RESISTANT
Eye Protection: SPLASH GOGGLES
Other Protective Equipment: APRON, IMPERVIOUS CLOTHING IF NEEDED.
Suppl. Safety & Health Data: SPECIAL FIRE CONT'D: WATER SPRAY MAY BE USED
TO FLUSH SPILL AWAY FROM EXPOSURES. MINIMIZE BREATHING OF GASES/VAPORS/
FUMES/DECOMPOSTION PRODUCTS. HEALTH HAZARDS CONT'D: INHALATION: REMOVE TO
FRESH AIR. GIVE CPR/OXYGEN IF NEEDED. INGESTION: DON'T INDUCE VOMITING.
OBTAIN MEDICAL ATTENTION IN ALL CASES.
Transportation Data
Disposal Data
Label Data
Label Required: YES
Label Status: G
Common Name: MYSTERY OIL
Special Hazard Precautions: SKIN: PROLONGED/REPEATED CONTACT W/PRODUCT
VOMITING MAY CAUSE MILD TO SEVERE PULMONARY INJURY. IRRITATION
Label Name: MARVEL OIL COMPANY INC
Label Street: 331 N MAIN ST
Label City: PORT CHESTER
Label State: NY
Label Zip Code: 10573-3305
Label Country: US
Label Emergency Number: 914-937-4000
   / fuel additives #17
Mineral spirits is the primary solvent for allot of diesel fuel additves.
   / fuel additives #18
Did somebody say something? I almost thought I heard something...
Soundguy
   / fuel additives #19
Hey, I said "if I recall correctly". I knew it had mineral spirits of various types was was unsure of the amount. Thanks for the MSDS as I misplaced my original.
   / fuel additives #20
Yes, mineral spirits are the primary solvent for most diesel fuel additives.
2011 Chevrolet Camaro Convertible Coupe (A52377)
2011 Chevrolet...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2016 FREIGHTLINER...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
2015 Volkswagen Jetta Sedan (A53424)
2015 Volkswagen...
