Fuel filler cap came off
   / Fuel filler cap came off #11
I’d re glue it back in with some GOOP adhesive, I use goop all the time, fantastic adhesive in a lot of applications. Same company makes another adhesive called 6000 that is even stronger but more difficult to pull apart if needed. I always clean parts to be glued with isopropyl alcohol before hand
Thanks for the adhesive brand suggestion. I will be trying to get some. As far a removing later, I can't think of a reason to ever remove it.
   / Fuel filler cap came off #13
Couple tips when using either goop or e6000 ; I’d pick a day to re glue it when you know you won’t need the tractor for a few days after, important to let it fully cure for a few days. Put some weight maybe 5-10 lbs on the inserted flange top. And lastly don’t try to wipe off the excess that squeezes out when it’s fresh. Just let the excess fully cure and dry then cut it free with a sharp knife and pull free
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
17201 (A55852)
17201 (A55852)
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A55851)
2016 Godwin CD150M...
INGERSOLL RAND AIR IMPACT (A55745)
INGERSOLL RAND AIR...
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
