FUEL FILLING FIASCO
   / FUEL FILLING FIASCO #11
I bought 2 5-gallon diesel containers from Lowe's. The nozzle has a spring loaded end on it. Nothing comes out unless the outside sheath of the nozzel is depressed. When you turn the can over to pour there is a plastic clip which rests on the edge of the fuel tank filler cap. The weight of the can and diesel keeps it depressed. As soon as you let up on it the fuel stops flowing. No spills since diesel doesn't flow until the end of the nozzle is in the gas tank. I will, however, invest in a bigger fuel storage tank sooner or later.
   / FUEL FILLING FIASCO #12
</font><font color="blue" class="small">( </font><font color="blueclass=small">( I am wondering what you folks use to fuel )</font>
The tank is 5.8 gallons. I use two 2.5 gallon Blitz-style plastic jugs. Those aren't bad to hold over the inlet. That's enough for 10-12 tach hours.
A question on my fire insurance renewal was "any fuel stored onsite?" I answered no and since then, purchased fuel goes right into the tractor.
)</font> <font color="red"> Why in the world would anybody store fuel inside anyhow???? </font>
   / FUEL FILLING FIASCO #13
</font><font color="blue" class="small">( I bought 2 5-gallon diesel containers from Lowe's. The nozzle has a spring loaded end on it. Nothing comes out unless the outside sheath of the nozzel is depressed. When you turn the can over to pour there is a plastic clip which rests on the edge of the fuel tank filler cap. The weight of the can and diesel keeps it depressed. As soon as you let up on it the fuel stops flowing. No spills since diesel doesn't flow until the end of the nozzle is in the gas tank. I will, however, invest in a bigger fuel storage tank sooner or later. )</font>
There have been several complaints with these no spill cans.
Also you can't use one to pour into MR Funnel.
   / FUEL FILLING FIASCO #14
</font><font color="blue" class="small">( <font color="blueclass=small"> "There have been several complaints with these no spill cans." )</font>
What kind of complaints? So far they have been OK for me. Should I be watching for something?
   / FUEL FILLING FIASCO #15
I use this type of no spill can as well. Not a single problem as far as fuel spillage is concerned. I'm with RobA: Is there some other issue with these cans to look out for??
Regards,
Duber
   / FUEL FILLING FIASCO #17
I use this Han-D-Pump from TSC. Harbor Freight sells the same one for about 3 bucks more.
   / FUEL FILLING FIASCO #18
I'm with you Thom. I don't want to go all the way to my red dye diesel dealer with 2 or 3 - 5 gallon Blitz cans. I roll my 30 gallon Handy into the truck, fill it up and it fills my tractor up 3 times and repeat the process. The crank takes 200 turns to fill up an empty tank. My right arm does the cranking while the left holds the hose. I don't notice any difference in muscle size on either arm. I crank it backwards and it sucks whatever fuel is in the hose back into the tank. It works, my back appreciates it and it is conveniant. I suppose a 12 volt powered pump would make it easier but I'm already soft enough.
   / FUEL FILLING FIASCO #19
No kidding, we've got six hard working diesels to fuel up and that gets old real quick with cans......
   / FUEL FILLING FIASCO #20
I used to stick a piece of clear tubing on the end of the nozzle to extend it. The 6 gal plastic can rested on the loader arm the whole time I was filling and when done, I rocked it back and caught any drip with the fuel cap. It seemed like a simple solution at the time.
Sure is easier now with my 150 gal tank, especially when I'm still using the diesel I paid $1.45 for last summer. /forums/images/graemlins/smile.gif
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2018 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2018 KOMATSU...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A51572)
1996 International...
2020 KUBOTA RTV...
