Fuel issue
   / Fuel issue #1
ALKY
bedford co. pa
tym 233hst
233tym Tractor has not run in years. Replaced fuel filter, pump, and injectors. Problem is it only runs smooth with #2 injection line cracked loose. Tighten it. It stalls. Foam is coming out. Ran fine for several minutes, tighten line it stalls. Any suggestions?
Assuming it's in the injection pump.
   / Fuel issue #2
I would start with the injectors. If the other two are getting fuel in the correct amourt to run, than I doubt it is the pump. The pump is simply a cam with some followers which are the pump cylinders.
Check around for Mitsubishi S3L parts. there is a guy offering the complete set of three on eBay For around $50.
The lowest I have seen for a used fuel pump is $400.
   / Fuel issue #3
Is the return line from the injector clear and working right??
   / Fuel issue #4
It’s very possible that the injector is stuck open.. & when u tighten it, the compression is blowing back into the pump, shutting it down..
A very easy test would be to swap it to another cylinder and see if the problem follows the injector..
I can redo those injectors for u..
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
5004 (A55851)
5004 (A55851)
Toro (A56857)
Toro (A56857)
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
2009 CHEVROLET C8500 DUMP TRUCK (A59823)
2009 CHEVROLET...
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
