Oil & Fuel Fuel Station
   / Fuel Station
Highbeam, the flow rate is 4 gpm.
rvtech,to refill the drum,all i do is disconnect the flex hose on the dip tube,undo the strap that holds the drum on the hand truck and load it in my p/u and refill at my co-op.I only have to do this maybe every 9-10 months.I also add a diesel treatment to this drum when i do refill it
   / Fuel Station #14
Do you use a pallett and loader forks to unload when full?
I have 2 250 gallon waste oil containers. I was considering having 1 exchanged for a new one so I could use it for diesel. The 250 gallon containers are hard to load/unload so I want to check on getting diesel delivered to see if it's worth doing.
I like your pump. That would work for any container.
   / Fuel Station #15
Funny, just 3 days ago I thought of a similar solution as I was tired of 5 gal containers and a stool to fill my CUT.
This is (attached) what I came up with.
Same basic idea with a different twist.
   / Fuel Station #17
<font color="blue"> 1*Do you use a pallet and loader forks to unload when full?
The 250 gallon containers are hard to load / unload so
2*I want to check on getting diesel delivered to see if it's worth doing.
3*I like your pump. That would work for any container.
~~~~~~~~~~~~~~~~~~ </font>
1*I would mount the tank to a dolly instead of a hand truck.
This way you can load and unload the tank ( Full or Empty } without using a pallet or loader forks.
2*You should be able to get the cheeper off road fuel delivered to a 250 gallon tank.
3* I would rather not have the pump mounted to the tank - this way you don't have to fool with taking it to the station when you fill the tank.
   / Fuel Station #18
</font><font color="blue" class="small">( Funny, just 3 days ago I thought of a similar solution as I was tired of 5 gal containers and a stool to fill my CUT.
Same basic idea with a different twist. )</font>
What did you use for your tank?
How much does it hold?
   / Fuel Station
LBrown59 , to fill my drum when it's close to being empty, i just pick it up and place it on my p/u truck,to unload i back my truck in the shed and use a strap over my roof truss and chain hoist with a special (made for drums )drum clamps.If you need a picture i'll get one when i get a chance.Around here most fuel co. won't deliver fuel unless you get 100gal. or more.
mike
   / Fuel Station #20
I have a discarded 2-250 gallon heating oil tanks the I use for diesel. I put a 110 volt transfer pump on one and they are plumbed together.
I think my total cost was around $200.00 and I have either 250 gallon capacity or 500. 250 if I shut one tank off.
Both tanks have Scully level indicators on them and pressure vent caps.
UNUSED FUTURE JBD 32" MIXING BUCKET (A58376)
UNUSED FUTURE JBD...
2017 Toro Greenspro 1260 Towable Greens Roller (A56857)
2017 Toro...
2025 GPS GT612 S/A 12ft Utility Trailer (A56859)
2025 GPS GT612 S/A...
2015 Dodge Charger Sedan (A56859)
2015 Dodge Charger...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58216)
2018 LARK UNITED...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
