Fuel wood dilema
   / Fuel wood dilema #11
My wood stove needs are settled. And its sort of weird. I found a Mill that gives the cut offs away. And that mill is close by and the way I drive home any way. So its free. All I have to do is cut some of it down to 14 inches to fit the stove.
This is odd in the sense, that I'm not cutting stuff on the property anymore. And I should be. But this is easier. :)
   / Fuel wood dilema #12
I've done lots of both, and there are trade-offs. Logs rot, much faster than rounds. You get about 2 years, maybe 3 max, out of stacked logs around here... and that's if you have them up off the ground on sleepers.
Rounds will dry and check a bit, not enough to be stove ready, but at least enough to slow the rot. That said, moving rounds is a total PITA, versus just scooping up logs with your pallet forks!
I usually keep between 20 and 40 cords of wood on-hand, with never less than 20 cords split and stacked. But I have precious little time for processing firewood, so I always favor speed and efficiency (moving logs) over preservation (storing rounds).
2019 Chrysler 300 Sedan (A55853)
2019 Chrysler 300...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
XCMG CV83PD (A53317)
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2018 JLG 2632ES 26ft Electric Scissor Lift (A53421)
2018 JLG 2632ES...
