Fuse #2 Frustration (Class III Boomer)
   / Fuse #2 Frustration (Class III Boomer) #1
jinman
Rest in Peace
Texas - Wise County - Sunset
NHTC45D, NH LB75B, Ford Jubilee
I was rotary cutter mowing last Monday for most of the afternoon. As I was almost finished, my wife came driving up on our Kawasaki Mule to bring me some cool water. I shut off the tractor and had a drink before attempting to restart, but the infamous PTO lamp was on with the PTO disengaged and I knew exactly what that meant. Since it was fairly late in the day and the tractor was just in a good place, I left it for the night and returned to my house with my wife.
Since we were having a 4th of July party on Wednesday, I just left the tractor sitting until yesterday, when I had time to return with fuses in hand. After two new 10 amp fuses popped on attempting to start the tractor, I knew this was going to be more than the average problem. I had to go somewhere yesterday afternoon, so it was today before I could return.
With my electrical schematic, VOM, and jumpers in hand, I returned this morning, determined to get the tractor going. What I found was that the fuse would not blow if I unplugged the fuel cutoff solenoid. I made a couple of inline ammeter readings and found that the solenoid would sometimes pull more current than at other times. It seemed like it was erratic. I cycled it on and off with a jumper about a dozen times and then replaced the fuse and put the wiring back to normal. The tractor fired right off and after several trys, would not blow the fuse again.
In my opinion, this problem now appears to be associated with the fuel cutoff solenoid. I think I'll increase the size of fuse #2 to 12 or 15 amps and see if that doesn't cure the problem. I just think that the solenoid sometimes drags a little and pulls enough extra current to blow the fuse. That's what my meter reading showed as it sometime indicated around 7 amps and at other times around 10 amps. The rest of the load was only 0.39 amps altogether, so I'm pretty sure the solenoid is the culprit for this problem rather than a "relay race" as I previously thought.
I changed fuse #2 to 15 amps last night after the 10 amp fuse blew again. I bought two packs of 15 amp fuses after the 10 amp blew again. I had it working fine for awhile, but it didn't last. The 15 amp fuse seems okay so far. We'll see...I'll report any changes.
   / Fuse #2 Frustration (Class III Boomer) #3
You've got a TC40 right?
look at the main wiring harness where it comes over the engine.
My whole wiring harness was replaced, it had rubbed right thru
did exactly that
No matter what, you've got a dead short somewhere, start tracing that wire and somewhere it's rubbed thru.
   / Fuse #2 Frustration (Class III Boomer) #4
Jim you might want to try a time delay fuse such as a MDL (motor delay). You will still have the protection of the 10 or 12 amp rating but with less nuisance tripping. Sometimes with inductive loads even doubling the rating on a fast blow will still not keep it from tripping. Also, better check what Cowboy says.
   / Fuse #2 Frustration (Class III Boomer) #5
Might be time for a CB.. like for a power window motor.. etc..
My 7610s did that a couple times on a lower amp fuse.. but a 10a has been holding for now.. I think they had a 5A in there originally!!!
Soundguy
Brian, it's not a dead short. I read the current with an inline ammeter. It would sometimes go as high as 12 amps and then settle back to 7 to 9 amps. A dead short would either instantly blow a fuse or fry a wire. This is just an erratically high load that can be completetly eliminated by disconnecting the fuel cutoff solenoid. It could be a fault internally to the solenoid, but if it is, it will get worse and I'll soon be blowing my 15 amp fuse. If that happens, the solenoid will get replaced. I also considered putting the solenoid on a separate circuit with a switch to activate it, but I'm not ready to rewire that circuit just yet. I like the protection of not being able to start the tractor if the PTO is engaged or the transmission is not in neutral.
I have a TC45D that's a 2001 model. I think on some tractors, New Holland replaced the fuse with an auto-reset circuit breaker. That or the MDL fuse mentioned by Shaley could be a solution. As Soundguy also noted, the solenoid is an inductive load and can be problematic like a motor load in a power window. Over their lives, these loads can have fluctuating starting current requirements best handled by a CB or a delayed fuse.
   / Fuse #2 Frustration (Class III Boomer) #7
Keep us posted on what you find / eventually have to do to fix it. I realize it may be a good length of time down the road.. etc..
Have you noticed that outside temperature effects it any?
Soundguy
   / Fuse #2 Frustration (Class III Boomer) #8
Jinman Hello. We traded a few posts before when I had a bad relay on the lighting system that was a bugger to find but eventually we can track down the problem sometimes even better than the dealer. On your problem I have no suggestions! since if you go back and read all your posts you have done a great job of troubleshooting already. You probably have isolated the fuel solenoid as a root cause correctly and not knowing the cost may want to get one or maybe if available you could replace the coil inside by shopping a bit. Not sure how difficult these are to take apart but if something goes together, ....
Solenoid coils when overheated can draw excess current and also if the plunger is not fully retracting can add a continuing higher electrical load on the coil resulting in a higher draw. You might try externally energizing the solenoid a number of times to see if there's a difference in sound or buzzing indicating the plunger isn't fully retracted. Not sure if it can be cleaned, etc.
Good luck and what a great forum where we get great ideas from each other to get through those crazy headaches...
I hate being wrong.... I hate it even more when I'm right and it costs me money.:p
The dang solenoid finally shorted out, smoked, and stunk up the place.:eek: For the "bargain" price of $81 and change, I now have a new replacement. I'll show the installation soon with photos. In the meantime, I cut the end off the old solenoid to find out if it could be repaired. It can't; it's an interesting but simple solenoid that shorted out internally and finally fried. I'll post some pictures of that by this weekend too.
So...if you are blowing fuse #2 on a Class III Boomer, it may be due to a failing fuel cutoff solenoid. Mine lasted 2000 hours, so I guess I should feel lucky.:rolleyes:
   / Fuse #2 Frustration (Class III Boomer) #10
I'll have to keep that in mind when my 7610s gets high hours.. I wonder if they use the same solenoid.
So.. was it an insulator failure? Phenolic washer split?
Soundguy
   / Fuse #2 Frustration (Class III Boomer) #11
Jim, sometimes you can do a voltage drop test and determine whether there is a problem in the circuit. If you hook one end of the voltmeter to the lug of the switch and the other to the post on the solenoid or what ever, you may be able to determine if there is a bad wire, or connection. But, since it gave up completely no need to go further. You can do this with any of the wires on there.
I had an old 58 Chevy one time that wouldn't start. And, every where I checked, it had 12 volts. Turned out that the battery cable was almost broke in two on the post connector. There must not have been over two or three wires that were not broken. At any rate a voltmeter still checked 12 volts. There just wasn't enough amps to make things work.
You were right it was not a dead short. Or it would have blown fuses just as fast as you could put them in. I have a short detector that you put in place of a fuse. It is nothing more than a circuit breaker and it has a meter that you run over the wire as the breaker comes on and goes off. You just follow the wire until the meter goes dead and you have found your short. SOMETIMES LOL
Soundguy
The solenoid is just what you would expect. Its a moveable piston attached to a plunger and surrounded by electromagnet windings. An internal spring pushes the plunger and piston out when not energized.
Since the part failed over time with increasing current and heat, I think it is likely that the internal windings shorted out, winding to winding, and then started drawing excess current. The added current caused the wire to heat up and melted the potting compound until the wires came in direct contact with the grounded case. At that point, the solenoid was hot, smoking, and blew the higher amp fuse. Luckily, the lead going to the solenoid didn't get hot or I might have had a much more serious problem.
I checked the solenoid with a 12 volt battery and jumpers after I took it off my tractor. The solenoid would not operate, but I read a dead short to the case from the input spade connector and it got hot in a hurry when connected to the battery.
I'll post some pictures of the two solenoids this weekend.
   / Fuse #2 Frustration (Class III Boomer) #13
Yikes.. a coil failure... I don't like those.. not that a 'contact' failure is any better...
Glad this wasn't a 'flaming' problem..
Soundguy
Here are some pictures of the new and old solenoid. On the new solenoid, you can just see a gray washer on the threaded end. It contains an o-ring that seals the opening when screwed into the injector pump. Evidently, the valve inside the pump is surrounded by fluid. In the third picture, you can see the internal o-ring on the cone shaped piece I cut off the back of the solenoid. That keeps the plunger sealed at both ends.
There is an internal coil spring missing because it went somewhere in my garage and I haven't found it yet.:rolleyes: You can see the spade connector is burned and so is the potting compound. It stinks.
I checked the new solenoid with my voltmeter. It is exactly 12 ohms through the coil. That means it should only pull 1 amp. Even I can do that math.:)
I'll get some installation pictures tomorrow if it isn't raining. It's pretty darn simple; you don't even have to raise the hood.
   / Fuse #2 Frustration (Class III Boomer) #15
Jim,
Do you think this might be associated with the prior Fuse #2 events described in the past for other folks?
DocHeb said:
Jim,
I sure do Chris. New Holland has a new part number for this solenoid. My guess is that the coil on the new one does not pull as much current as the old one. Unfortunately, my old one was failing before I figured this out, and I could not accurately measure the resistance to ground. If someone with an older tractor could measure the resistance of their solenoid's coil, it could help us decide if this is a possible reason or just a coincidence. It's stuffed in behind the fuel filter on the back of the injector pump and not all that easy to get to. After I post pictures of my installation tomorrow, it will be easier to see where to look for the solenoid.
   / Fuse #2 Frustration (Class III Boomer) #17
I'll check the one on my 02' 7610s tomorrow and post back.
Soundguy
Here are pictures of the solenoid installation. I removed the top two hoses to my FEL so I would have more room, but that's all I had to do. You can see just how easy it was to replace the solenoid.
...and it works great. It only gets warm to the touch, not hot. I mowed all day without a problem. I think I can put this problem to rest.:)
   / Fuse #2 Frustration (Class III Boomer) #19
Jinman, I think your increasing the fuse size helped you resolve the problem. With the lower current fuse the fuse blows before the solenoid seriously overheat from the erratic short. Once you put the big fuse in the solenoid could keep getting power and heat up, further damaging the solenoid and helping you isolate the failure. Sometimes you have to force a failure. A hair dryer might have helped.
FYI, a DC solenoid does not pull more current if it sticks open and does not "buzz". An AC solenoid does pull more current when open and if mechanically jamed open will burn up or blow a fuse. Some DC solenoids have a switch in them that opens when the solenoid engages and puts a resistor in series with it. These do pull more power when open, but they are very rare. I have never seen one.
Good job of trouble shooting.
   / Fuse #2 Frustration (Class III Boomer) #20
Thanks for posting up those pics Jinman...
I was washing my machine just yesterday and was lookin for that lil solenoid in order to give it a quick inspection...couldn't find that durn thing, aparently it was directly in front of me.
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
Kubota M6 131 HP
Kubota M6 131 HP
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
