Fuse project
   / Fuse project #11
Sounds like a classroom type demo. Get some fractional (or at least very low) amp fuses, some wire, some alligator clips, and a nine volt lattern battery. Make up two wires with clips on each end. Clip a wire to each side of the fuse. Then clip/touch each wire to the battery posts
   / Fuse project #12
good idea, or maybe a 12v battrery and one lamp that draws less than 1 amp and another one that draws 2 amps. Use a 1 amp fuse. get the idea ?
   / Fuse project
IH3444 said:
Are you going to post a picture of the poped fuse? Or better how about a mini video?
I will definitely do a video.
Bob
   / Fuse project #14
Nine volt lattern battery??? :confused: I am not sure where my head was. A 6 volt battery or put 2 together to make a 12. Even though they are 12 volt fuses, a 6 volt battery would blow it.
The light bulbs are a good idea. And if you wanted to get fancy, use a variable resistor so you could gradually increase the current, watch the bulb grow brighter, then POP, all goes dark.
   / Fuse project #15
How about a small 12 volt battery charger? Use a 10 amp fuse and start the charger up on the "low" ex. 2 amp setting showing that the fuse can handle that much current, then switch the charger up to the high setting and watch the fuse burn in two.
   / Fuse project
Would it blow the charger???? I know this is a silly question, but I am good at that?!
Bob
   / Fuse project #17
I am thinking you may be doing this in a class with Kids? And I am guessing that you are willing to put at least a little time into it.
How about a small battery etc. then a series of switches that you can add in various size rated light bulbs one at a time
If you had say 5 or 10 individually switched bulbs, of assorted sizes, then you can play a game with the kids of which can work, and they will see the various results, kind of cause and effect, and it will draw them into the demo instead of letting them just observe.
I would do it with 12V stuff as that is plentifull, and you could do something like say, a driving light, a tail light (like an 1157 with 2 filaments) a headlight maybe a dome light or clearance light, or maybe some LED trailer lights.
I guess it is all in how much time and $ you would be willing to put into it. I know several stores have helped considerably, or just flat given me stuff when I have done it for my kids school, and explained to the manager what I was doing. Heck, make it nice and the auto parts store may want it as a demo for the guy that comes in and just does not get it why he cannot run his driving lights, car stereo with Mega amp and 8 cell phone chargers of that 10a fuse tap :)
   / Fuse project #18
Bob
No- because on the 2 amp setting, the charger should only be making about 2 amps. On the high setting, the fuse will blow. My small charger has an internal thermal circuit breaker that will cut out if it shorts out.
2022 FORD F-250 CREW CAB TRUCK (A59823)
2022 FORD F-250...
Chevrolet 2500 Flat bed (A56436)
Chevrolet 2500...
Sedan (A59231)
Sedan (A59231)
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
2022 KAUFMAN 2 CAR TILT GOOSENECK TRAILER (A59575)
2022 KAUFMAN 2 CAR...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
