If you have a 2 ton cherry picker, the 1 ton setting MIGHT be enough reach to get over the BB - if so, rig at least 3 slings (toplink + 2 corners for better balance), pick it up, and CAREFULLY drive out from under it.
Once on the ground, your tractor specs say 1631 pounds lift @ 24", so the tractor should be able to lift it (I would probably get a bucket full of material first, assuming your tractor has a FEL)
If your tractor's FEL is like a friend's JD 790, there's no way it would lift an 1100 lb Gannon but once on the ground, the 3PH should.
Agree with others' comments on not being in a hurry, but having an 1100 pound "paperweight" in the bed of your truck might be a tad inconvenient :laughing: ...Steve
