Gardening help
   / Gardening help
This forum is great! Thanks for the input. That TAMU sight was very enlightening and just what we needed. And ...yep, the 1/3 acre thing aint happening. Waaaaay to much to take care of and plant for just our immediate family and some neighbors. I guess it was a newb mistake as well....We cut it back to 50'x90' or so. :D And thanks for the pics of the hillers.....Mark,your check is in the mail :laughing: I'll take pics this evening for ya'll!
   / Gardening help #12
This will be the first year we will be taking on a garden of much size.(1/3 acre) It will also be the first for planting different vegetables for the first time..such as potatoes,asparagus,watermelon,and cantaloupe to name a few. Is there a website that may help us with some basic knowledge in setup,care,irrigation,timing,etc?
Also, I would like to make the beds mounded rows....I do not see an implement around our immediate area being sold that does this. So...can I take a cultivator,remove some tines, install a couple of discs mounted almost 90 degrees to the direction of travel to do this? What would be a good row spacing?
....as you can see,we need some input! Thanks!
BTW, I have a new JD 2520, 60" tiller, box blade ...if that helps with input. I can weld...and wouldnt mind making my own "hiller",and can copy a design or picture if its cost effective.
thanks...
I see you listed a tiller. I just threw out a brochure for a DR brand tiller. It offered a hiller option that can be attached to the rear of the tiller. You might get some ideas from that.
   / Gardening help #13
to deal with weeds between the rows. make sure you space the rows far enough apart, that you can take a walk behind tiller. and just go down the rows. and till the weeds in. pulling weeds is a pain, and this makes it much more easier.
as far as irrigation. just a standard lawn sprinkler works when ya first plant everything, then as the plants get higher, tossing a milk crate under the lawn sprinkler to raise it up some.
but as the plants get taller. milk crates start to tip over. and that is when ya break out. A frames made out of pvc pipe or small lumber say 1" x 1". to hold the sprinkler even higher.
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
CAST IRON POT (A58374)
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A56857)
2025 ZWB 59in...
2016 FREIGHTLINER CASCADIA SLEEPER (A58018)
2016 FREIGHTLINER...
2010 New Holland TD5050 95HP 4WD Agricultural Tractor w/ Bush Hog 2610 10ft. Rotary Mower Attachm... (A55973)
2010 New Holland...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
