Gas leak Cub Cadey LT1018
   / Gas leak Cub Cadey LT1018 #1
DownNBama
My LT1018 has a gas leak at the bottom of the gas tank. Thinking it may have been the fuel line, I replaced it. No such luck....thing still leaks. Anyone else have a similar problem? If so, how did you fix? I'm in a rural location and it's a pain to load the thing up on a trailer and take it into a dealer.
   / Gas leak Cub Cadey LT1018 #2
Contact your local Cub Cadet immediately.
Please refrain from using the unit till the fuel leak is fixed.
Also, when you get on or off the tractor, DO NOT apply force to the gas tank cap(ie-using it as leverage to get off the tractor). This will cause the plastic tank to split/leak.
   / Gas leak Cub Cadey LT1018 #3
If your cub is less than 1 year old, the cub dealer will pick up,repair and return your mower without charge. Read your warranty packet, lots of good information /forums/images/graemlins/smile.gif
ASSET DESCRIPTIONS & CONDITION (A58017)
ASSET DESCRIPTIONS...
Rooster Artwork (A55758)
Rooster Artwork...
Toro Workman HD Utility Cart (A56857)
Toro Workman HD...
VINTAGE GAS PUMP (A58374)
VINTAGE GAS PUMP...
2017 Freightliner MT55 Step Van (A56858)
2017 Freightliner...
Lone Star dump trailer (A55973)
Lone Star dump...
