Gas with Ethanol in Small engines.....Do not run engine dry for storage.
   / Gas with Ethanol in Small engines.....Do not run engine dry for storage. #21
My local Stihl dealer recommends running dry for over winter storage.
We do not (AFAIK) have Ethanol in our petrol (gas) here - but he says the additives used to reduce pinking and overcome the other "environmental" enhancements to fuel tend to gum up carbs over winter.
He claims he is busy every spring replacing gummed up carbs.
As an aside, if I can slip a "front porch" question in here - with all the grain shortages, ought we still to be diverting foodstuffs from feeding people into fuel production?
J
   / Gas with Ethanol in Small engines.....Do not run engine dry for storage. #22
Govment says yes!
   / Gas with Ethanol in Small engines.....Do not run engine dry for storage. #23
I am lucky enough to live 15 miles from a coop that sells ethanol free gas which I use exclusively for all my small engines and give the caddy a tank of it every time I am there.
   / Gas with Ethanol in Small engines.....Do not run engine dry for storage. #24
Ethanol impregnated gas is good for over a year with a stabilizer. Why would you need anymore storage time than that?
   / Gas with Ethanol in Small engines.....Do not run engine dry for storage. #25
No stabilizer can negate/offset the bad effects of ethanol. It's a completely different set of issues.
   / Gas with Ethanol in Small engines.....Do not run engine dry for storage. #26
Storage in a tank is different than storage in a carburetor.
   / Gas with Ethanol in Small engines.....Do not run engine dry for storage. #27
Stabil does not keep Ethonol from absorbing 10x its weight in water over time, thus settling out to the bottom and you end up with a lean burn situation which will burn up your out board pistons once that fuel is used.
   / Gas with Ethanol in Small engines.....Do not run engine dry for storage. #28
I have noticed on a lot of my small 2-cycle engines that the fuel pump bladder inside the carb has deteriorated and is torn or ripped. I don't know if it is from ethanol or just poor materials in the bladder. About every two years, I have to replace all hoses, the priming bulb, and the bladder. I actually bought a couple of brand new carburetors for around $30 each. I can replace a whole carb really quickly for far less than taking them to the shop. Then, I can fix the old carbs when I get around to it. I never used to have this much trouble with my 2-cycle engines, but nothing lasts over a couple of years now without some rubber part or multiple parts falling apart.:(
   / Gas with Ethanol in Small engines.....Do not run engine dry for storage. #29
Sounds like it might be cheaper to use non ethanol fuel, most manufactures dont recomend it, some void warranty. If you cant get non ethanol fuel locally, check at a marina, airport or race shop. Ethanol does atract water, when I was racing, the guys that run straight alcohol, drained fuel from tanks back into barrels after the race to prevent taking on water.
Dave
   / Gas with Ethanol in Small engines.....Do not run engine dry for storage. #30
Govment says yes!
No, the grain producers installed congressmen in office to represent their interests. Congress wrote the laws that 'government' has to enforce. Congress is the focal point for this problem.
Zero Turn Mower (A59231)
Zero Turn Mower...
Informational Lot - Shipping (A56436)
Informational Lot...
1605 (A57192)
1605 (A57192)
Unverferth 25' Head Cart (A59814)
Unverferth 25'...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2018 F150 (A56436)
2018 F150 (A56436)
