Gator 6X4 drive chains
   / Gator 6X4 drive chains #1
PapaG
Somerset Kentucky
dealer said my drive chains are stretched, and they need replacing soon. wouldn't you know it, 1 day after getting it back the chains come off, and they sag badly.
did the dealer do something to my Gator. how hard is it to fix, whats needed etc???
   / Gator 6X4 drive chains #2
The new chains will stretch. Jack up the rear end and remove the rear wheels. Loosen the bolts holding the hubs onto the frame. There should be a take-up bolt on each side at the rear of the hub. Tighten each side equally but the chains should still have a slight sag. You might have to do this a few times before the chains get the intial stretch out of them. Use an aerosol chain lube that will be dry on the chain.
   / Gator 6X4 drive chains #3
Keep an eye on your sprockets also. If you run the life out of the chain you end up wearing the sprocket beyond the service life.
Towable Chemical Applicator Sprayer (A59228)
Towable Chemical...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
2022 CATERPILLAR 299D3 XE SKID STEER (A60429)
2022 CATERPILLAR...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
2011 Ford Expedition 4x4 SUV (A59231)
2011 Ford...
