Gator Blades for Zd326p
   / Gator Blades for Zd326p
Your probably correct they aren’t the same blades you have. This is where I ordered they from, they list them to fit ZD326. My ZD ORIGINAL blade number is K5647-34340, it crosses over to the blades I received. Gator blades maybe good,but the company’s cross over isn’t what it should be.I’ll stick with Predator brand.
Sponsored
Oregon 3PK Gator 96-363 Blades Replacement for 60" Kubota K5647-34330 K5647-34340 Fits on ZD21, DZ28, ZD323, ZD331, ZG327, ZD326S, ZD21F-60P Models
Roll over image to zoom in
   / Gator Blades for Zd326p #22
Call me blind in one eye and can see out of the other but the Orgon site lookup shows the 96-363 as a replacement for these Kubota blade numbers (not K5647),
  • K5645-34330,
  • K5645-34340,
  • K5645-97520,
  • K5645-97530,
  • K5651-34330,
  • K5651-34340
oregonproducts dot com/en/blade,-kubota,-gator-g3,-20-1-2%22/p/96-363
I could not look at what you were seeing, the links were filtered out. The fitment you posted looks like a copy and paste from Walmart, Amazon has the identical listing. Heading over to the Oregon site tells a different story. Orgon does not specifically list the ZD326, they must assume you know the ZD323 and up with 60" decks have the same blade.
At the Oregon site, if you looked up the Kubota blade number, it will lead you to three correct Gator blade part numbers.
I guess the moral of the saga for all of us is don't trust third parties for replacement part numbers, go to the horse's mouth.
Predators fit perfectly. Great mulching blades. Thanks for all your help.
1985 Miller Wildcat 350-D Welder (A54811)
1985 Miller...
2017 Harley Davidson Electra Glide (A52377)
2017 Harley...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2013 MACK CXU613 (A53843)
2013 MACK CXU613...
197711 (A51244)
197711 (A51244)
ROLL OFF BOX (A53843)
