Gator Blades
   / Gator Blades #1
perrycounty
Central Pa.
Cub Cadet
Does anybody here run Gator Blades on their CC?
I was talking to the salesman the other day and was ordering an extra set of blades for the 2544, he asked me if I had considered Gator Blades. He says they cut down on the dischage coming from under the deck as they are supposed to cut the clippings several more times during the cutting process.
Seriously considering ordering a set of these.
Input appreciated!
   / Gator Blades #2
I can promise you that they are well worth the little extra $ (sometimes they are about the same price as CC blades). They cut the grass up much finer, plus they are available for everything CC makes from the S series push mowers to the M72 Tank. Go ahead and get a set, you will like them.
   / Gator Blades #3
Hi Go to http://mowproducts.itcstore.com/
they have regular and Gator Blades for tons of mowers .and their prices cannot be beat! I have them on my CC1863 3 blade 54" cut and they work great. /forums/images/graemlins/wink.gif
   / Gator Blades #4
We sell hundreds of gator blades a year, they work great. I have them on my personal mower also.
   / Gator Blades #5
I'm a little curious about this /forums/images/graemlins/confused.gif The gator blades I have looked at are for CC models prior to 2001 (re: 759-3812 & 742-3002) They are 15-1/8" long. My 2544 (2005 model) uses the 759-3939 blade, which is 15.94". This is a difference of 3/4" length overall. This adds 3/4" more gap between the mounted blade ends from standard. Seems to me that you are inviting two strips of un-cut areas, which will increase as the blades wear down ??? /forums/images/graemlins/confused.gif
   / Gator Blades #6
There are gator blades avialable for all model CC...that includes all 2005 models. Just ask your dealer and if he can't help then I sure can!
   / Gator Blades #7
Are you sure they are out for all models? I haven't found some for a few... more specifically, the LT1042 model, for one instance.
   / Gator Blades #8
Yes they are out, if you want me to get you some send me a pm.
   / Gator Blades #9
</font><font color="blue" class="small">( I'm a little curious about this /forums/images/graemlins/confused.gif The gator blades I have looked at are for CC models prior to 2001 (re: 759-3812 & 742-3002) They are 15-1/8" long. My 2544 (2005 model) uses the 759-3939 blade, which is 15.94". This is a difference of 3/4" length overall. This adds 3/4" more gap between the mounted blade ends from standard. Seems to me that you are inviting two strips of un-cut areas, which will increase as the blades wear down ??? /forums/images/graemlins/confused.gif )</font>
I have to double check but those blades are the same that is offered on the 44" deck for the 3000 series....I have yet to find Gator blades for them -
http://www.oregonchain.com/OEP/oep_blades.htm
Oregon Gator Blades
   / Gator Blades #10
I just got an answer back from gatorblade. com concerning a blade for the new model 2544. Quote: " We do not currently offer a Gator Blade for your Cub Cadet tractor. Thank you for your interest though. gatorblade.com" You can buy the blade for the 48" mower. It is 16-17/32" long and grind off 1/4" from each end. Everything else is the same (center hole, width etc). /forums/images/graemlins/cool.gif
   / Gator Blades
</font><font color="blue" class="small">( I just got an answer back from gatorblade. com concerning a blade for the new model 2544. Quote: " We do not currently offer a Gator Blade for your Cub Cadet tractor. Thank you for your interest though. gatorblade.com" You can buy the blade for the 48" mower. It is 16-17/32" long and grind off 1/4" from each end. Everything else is the same (center hole, width etc). /forums/images/graemlins/cool.gif )</font>
The same thing basically happened to me. I E-Mailed Mow Products about Gator Baldes and they replied and told me that for the 2544, Gator Baldes were a dealer product. So now I'll contact the dealer and find out if in fact they do have them available and how much they are for a set.
   / Gator Blades #12
</font><font color="blue" class="small">( </font><font color="blueclass=small">( I just got an answer back from gatorblade. com concerning a blade for the new model 2544. Quote: " We do not currently offer a Gator Blade for your Cub Cadet tractor. Thank you for your interest though. gatorblade.com" You can buy the blade for the 48" mower. It is 16-17/32" long and grind off 1/4" from each end. Everything else is the same (center hole, width etc). /forums/images/graemlins/cool.gif )</font>
)</font>
As I said earlier the 44" blades are the same on the Cub 3000 series, and no there is no Gator blades available.....
/forums/images/graemlins/crazy.gif
   / Gator Blades #13
I checked a couple months ago for gator blades. They emailed me back and said to check back in November when their new catalog is done.
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
Takeuchi TB016 (A53317)
Takeuchi TB016...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
2021 CATERPILLAR 323 EXCAVATOR (A60429)
2021 CATERPILLAR...
