Gazebo Number One
   / Gazebo Number One
Eddie:
Why didn't you just use a galvanized post base for the bottom of your cedar logs?
I know they are for dimensional lumber, but you could trim the bottom of the post to fit with a chain saw and have something that was pre-engineered for the application.
Dave,
I considered them, but from what I understand, they are for porches where you have a building to lock the post into position with the roof. My concern is that this is totaly free standing without anything to stop the racking other then the bracing that I add to it. I have a few things that I am going to do to minimize the movement that I expect out of the design that I'm building, but anchoring posts to the top of concrete was something that I've been worried about.
My fear of the brackets is that they attach to the bottom inch or so of the post. While that's fine for a porch, I want A LOT more for my cedar log posts. I want bolts going all the way through in two places. In my mind, this will anchor it and add to the stiffness of the structure.
Another thing is that the cedar logs will be well over a foot thick at the base. I want them to be irregular and natural looking as much as possible. I don't know how I could do that with the post brackets.
Hope this makes sense.
Eddie
   / Gazebo Number One #12
You make perfect sense, but take a look at a Simpson CB1212 column base someday.
OTOH even that one says it is not for columns with unsupported tops.
Even with your C channel, somehow I think you end up needing shear panels on 2, or maybe 3 walls of your gazebo.
   / Gazebo Number One #14
My neighbor and his brother handle quite a few logs for their home built hydraulic powered bandsaw lumbermill. They built a gazebo-like structure similar to what you are making. For the 4 corners and top rails, they used steel beams. Then they sawed logs in half and cored them so that the log halves could be put back together wrapped around the beams. To core them, they used a chainsaw hardmounted to the mill framework and ran the sled slowly by it with a log half on it. The chainsaw was side cutting the wood as opposed to how a chaisaw would normally be used.
When screwed back together, it looks like the logs are the only support. You would need a magnifying glass to find the seams.
   / Gazebo Number One
I agree. In most designs, they use the railing for the sheer strength. I'm going to do the same with welding panels that I will make and fit in between the logs in four places. The half that doubles as part of the pasture fence will have the metal panels.
I'm also using metal angle brackets for the bracing at the tops of the posts to cut down on movement.
My concern is that with the metal panels all being on one side, that I might have movement on the other side. That's also why I went with the 3 inch C channel. I'm hoping it will compensate for the lack of any bracing at the bottoms of the posts for diagnal movement.
Eddie
   / Gazebo Number One
I was at an auction awhile ago and there was a very nice sawmill there that had hydraulic everything. This thing was amazing. Kubota diesel engine that fired right up. Probably a dozen or more levers to play with, plus a line of buttons to push. I really wanted it, and still do, but just cant justify the expense of it with so many other priorities out there.
Their use of steal would solve all my engineering issues, and allow it to be more open and attractive. I'm just hoping that I've figured this out and it works. Gazebo Number Two is going in on Lake Marabou and it's going to be bigger and taller.
Eddie
   / Gazebo Number One #17
Eddie I just took notice of the Title.
Gazebo Number ONE? So just how many of these things are you planning on building?
Wedge
   / Gazebo Number One #18
Can't wait to see some follow up pictures, been thinking about one of those myself for the backyard down near the pond.:thumbsup:
   / Gazebo Number One
Wedge
I will build three eight sided gazebo's for sure. This one, a massive one at Lake Marabou, and a smaller one on top of what used to Rifle Range Number 4, which is the 300 yard shooting position for what used to be Camp Fannin, a WWII replacement training base for the Army. It has a great view of Lake Marabou, and is a very unique feature on my land.
I will also build at least two small and two very large, square shaped, open sided gazebo's at some point. Everything is still flexible and kind of fluid as to what it will actually look like and how big they will be. I will wait longer to build them then to build them smaller to save money. There is no rush on any of it, so I get to have fun and try to create something unique.
Eddie
   / Gazebo Number One #20
OK, now comes the real mystery. The Gazebos are octagonal, but the post footings are pentagonal.
When I come to visit, I will look at this for a long time and then my head will explode.
What is the reason? And I know you have one...
2012 Dodge Grand Caravan (A56859)
2012 Dodge Grand...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
2015 Ford Transit Connect XL Cargo Van (A56858)
2015 Ford Transit...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
