GC 2300 getting ready to grind stumps
   / GC 2300 getting ready to grind stumps
glad you posted pictures and explained what you do.I'll have to give it a try so long as it's not too hard on my back[some days not good other days not bad] Larry:thumbsup:
   / GC 2300 getting ready to grind stumps #12
Using the dollies is a great idea. Harbor Freight has some cheap moving dollies that I picked up for when I drop my snowthrower and adapter. No more dragging it around.
   / GC 2300 getting ready to grind stumps #13
Perhaps a lot of others have figured this out and it's nothing new-- just new to me!
The main advantage I see is that only ONE joystick control/movement is needed for install or remove (and no tractor forward/reverse), and, with the lower pins in their sockets, the hydraulic lines are closer which makes for far easier connection. (You can probably tell I really fought with those hydraulic lines before....:laughing:)
Maybe this summer I can figure a neat trick for the BH as well-- taking off is easy, but lining everything up to go back on can be a challenge for me.
   / GC 2300 getting ready to grind stumps #14
Thanks for the tips for removing FEL. As a new owner of a GC2400, I haven't actually tried taking the thing off yet, but this certainly seems like a good idea. I also very much appreciate you taking the time to lay it out, step by step, with pictures.
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
pressure washer, and trailer (A56859)
pressure washer...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
2019 Ford F-350 4x4 Flatbed Truck (A55788)
2019 Ford F-350...
2019 Freightliner M2 106 AWD Altec AM55 55ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A56857)
2017 JLG Skytrak...
