GC 2610 w/ sticky reverse pedal....
   / GC 2610 w/ sticky reverse pedal.... #1
ozsevenzero
Massey GC 2610 TLB
My GC has roughly 90 hours on it and lately the reverse pedal sticks and stays in position until i remedy the situation with my foot by pressing the forward pedal. No biggie, but once in a while i take my foot off expecting it to return to the neutral position and it keeps going (wasn't too funny when the wife tried to move it and almost took out a lawn chair). Weird thing is that it doesn't do it the opposite way.
My question is this; is there any adjustment or major lubrication i should be doing to the linkages? I have sprayed the linkages with some lubricating oil and it still sticks.
   / GC 2610 w/ sticky reverse pedal.... #2
At the risk of the obvious, you have greased the zerk at the pivot, under the pedals, correct?
Yep, lubed everything possible.....only sticks when using reverse for more than a brief moment.
   / GC 2610 w/ sticky reverse pedal.... #4
Could be a spring tension adjustment.
   / GC 2610 w/ sticky reverse pedal.... #5
Check with the dealer if there is a service bulletin for the problem. There is one for the 23xx and I do not know if it covers 24xx,26xx.
Doug
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53472)
PENDING SELLER...
2018 KUBOTA SVL95-2S SKID STEER (A51246)
2018 KUBOTA...
2019 KEESTRACK K6 SCALPING SCREENER (A51246)
2019 KEESTRACK K6...
2020 COLOMBO TM LOT NUMBER 216 (A53084)
2020 COLOMBO TM...
2013 RAM 4500 (A50323)
2019 KOMATSU WA380-8 WHEEL LOADER (A51246)
2019 KOMATSU...
